Rear end sway while acceleration. Causing a hard pull to the right.
Old Sep 29, 2014 | 07:05 PM
turnerdirt's Avatar
Car: 1990 RS
Engine: 305 Tbi
The rear end on my 1990 RS sways to the right when at hwy speeds and tapping on the accelerator. I've replaced the pan hard bar, and rear control arms. Thought the new phb would do the trick. Is there something with the torque are that needs to be addressed? Is the rear axle wore out (there's no noise from it)? At a loss on what it could be.
Old Sep 30, 2014 | 01:46 PM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: Rear end sway while acceleration. Causing a hard pull to the right.
worn shocks, springs check sway bar bushing and mounts also need to be check , on my RS had a swaybar mount broke at the bolt , also you should thighten them with weight on car because it will bind
Old Oct 4, 2014 | 03:53 PM
turnerdirt's Avatar
Car: 1990 RS
Engine: 305 Tbi
The alignment on my car was great from the time I got the car up till I got new tires on it. Since then the rear end feels like it's moving out from under the car and it pulls to the right.
Everybody says to move the tires around. Which might help with the pull, but I think the rear is a mechanical issue.
Old Oct 4, 2014 | 09:36 PM
Formula 305's Avatar
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
If the only thing that has changed is tires I'd start there. It takes 15 minutes to rotate the tires, just do it quick and see if the pull moves to a different side or something.
hectre13
Dec 11, 2023 08:14 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
hectre13
Aug 26, 2015 08:17 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
mizz0313
Aug 12, 2015 06:45 AM
