Coil spring spacers
Old Mar 8, 2015 | 10:18 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Coil spring spacers
My my drop springs have the front of my car sitting far to low, with front wheels slightly tucked under the fender. I would like to raise the front by around 3/4-1" and just have the top of the tire nearly flush with the fender lip.
Is anyone running a particular type of spacer up front? and if so where can I get them? Also can V6 front springs give the desired height?
Old Mar 10, 2015 | 10:45 PM
plum92_camaro's Avatar
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
Re: Coil spring spacers
I would either get some moogs cut them down to height. ( a search will help you find the part #'s for the different stock spring options)
or just get a nice set of aftermarket springs. for a street car i would go with eibach. Check out the Official Lowered thirdgens thread in this section. It is great for seeing how these cars look on all the different aftermarket springs.
Old Mar 12, 2015 | 01:12 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Circle track companies sell them. They're pretty cheap. Around $20. You can get threaded ones for the rear. Around $20.
Many are of the cut to length type. So you can just measure what length you want to raise the car and cut them that thick.
I would suggest not wasting time on aftermarket lowering springs. You're never going to be completely happy with them unless you get lucky. Go with a Ground Control Weight Jack setup or just cut factory stuff... or what you have.
Old Mar 13, 2015 | 10:29 PM
Car: 92 Camaro RS
I agree with you IV. I love my weight jacks, I don't think there is a better option, but for the price The_Wraith could get two sets of aftermarket springs.
Old Mar 14, 2015 | 03:19 AM
Car: 1992 Camaro RS
That's exactly it, if you buy one aftermarket set of lowering springs and you're not happy with them, and you eventually end up buying another set, you would have been better off with weight jacks from the start.
MM2Robinson
Oct 1, 2017 09:16 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
lakeffect2
Sep 7, 2015 03:52 PM
Jlanz55
Sep 6, 2015 03:05 PM
