question about the gc weight jacks I just installed
Old Mar 14, 2015 | 03:18 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
I just put my ground control weight jacks on with kyb agx struts and I have it adjusted to the lowest setting possible and I'm only 1" lower then factory I can fit my fist between the tire and fender what could be wrong?
Old Mar 14, 2015 | 09:29 PM
midnightfirews6's Avatar
Car: 1984 Trans Am WS6
Engine: LG4
Axle/Gears: 3.23 LSD
Re: question about the gc weight jacks I just installed
Front, rear, or all four corners? And what are your spring rates and free lengths? Tire sizes? Pics? Hard to tell without more info. You could have tiny hands and stretched tires on 13x8's for all we know lol
Old Mar 14, 2015 | 10:13 PM
SlickTrackGod's Avatar
On Probation
He asked about the struts so he's talking about the front.
Do you have the springs indexed correctly? Is the weight jackers up on top of the springs or did you install them upside down on the bottom side possibly?
Old Mar 15, 2015 | 12:02 AM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
Front is 900# 5.5od 9.5" length rear are 250# pigtail 9" length. Tires are 275/35/18 front and 295/35/18 rear
Old Mar 15, 2015 | 12:03 AM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
Old Mar 15, 2015 | 02:10 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
You probably need shorter front springs. Your rears will be too tall too. I have some 225# rears that I got in case I went to stiffer front springs down the road, and they sit pretty high adjusted all the way down. You could either remove the isolator or the adjuster for the rear to sit lower, and between the two thats nearly an extra inch. But there's not much you can do about the fronts without going to an 8" spring.
OR....
Just an idea....
You can get some extended ball joints for the front.
That will net you an extra .5 or .75 inches depending on how long you get them. If .75" isn't enough to get it where you want... maybe not a viable option.
Old Mar 15, 2015 | 12:35 PM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
You sure there installed and index and setting in cup correctly
I have 900 and 200 rear no isolator all around
I raised them since then
Old Mar 15, 2015 | 04:21 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Yeah I have 1050 fronts and can get lower than that
Old Mar 15, 2015 | 07:18 PM
Car: 1992 Camaro RS
But did you guys check the uncompressed height of your springs? I'd bet you guys have 8 inch springs.
Old Mar 15, 2015 | 08:22 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
I have 800lb 9.5" springs on a v6 car and im still a lot lower.
Old Mar 15, 2015 | 08:39 PM
plum92_camaro's Avatar
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
Front springs come in 9.5" and 8". You should also check springs to make sure they are indexed properly in the a-arms and check the adjusters up in the K-memeber to be sure they are seated properly.
Old Mar 15, 2015 | 10:52 PM
camarozz383's Avatar
Car: 1989 camaro rs
Engine: ls 5.3 carb
Transmission: t56 six speed
Axle/Gears: 3:73
hey zach what springs are you running?
Old Mar 16, 2015 | 12:26 AM
Engine: 305 to 350
Axle/Gears: 10 Bolt
9.5 iirc
900front 200 rear
Also remember you have to tighten sway bar with weight on car it will create a bind and not settle all the way
Index front spring and make sure weight jack is sitting in pocket correctly also that can add a inch or so or less that alone if not checking for both
Rear isolated can knock around .5 in lower
Also bump stops can prevent lower stance also
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
