What A arm bushings?
Old Mar 28, 2015 | 09:41 AM
SOCAL-Z's Avatar
Car: 87' IROC
Looking at replacing the A arm bushings, should I get Energy Performance poly, Stock rubber or ?
Old Mar 28, 2015 | 09:58 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: What A arm bushings?
What are you doing with the car?
Old Mar 28, 2015 | 11:28 AM
SOCAL-Z's Avatar
Car: 87' IROC
Will be installing Founders Performance LCA with 3 piece poly bushings,LCA relocaton brackets,adjustable panhard bar with poly ends for the rear. Greaseable poly swaybar bushings and poly swaybar ends front and back so far. Thinking about getting Founders Performance strut mounts for the front. Just updating the cars suspension. Going to use the car on weekends and go to local runs and shows..
Old Mar 28, 2015 | 07:04 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
I had a bad experience with Spohn A arms, so I took my stock ones, and put in Global West Del a Lum A Arm bushings... they work great and no complaints....
http://www.globalwest.net/1982-1983-...uspension.html
Rafael
I also got the Founders 3 Way Poly LCA's and Panhard bar, nice pieces, great performance and price!
Old Mar 29, 2015 | 01:26 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
If you use poly bushings be aware there is a right and wrong way to install them.
Old Mar 29, 2015 | 04:04 PM
TTOP350's Avatar
The right way would be into the trashcan.
Old Mar 30, 2015 | 11:54 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
If GM has 1LE high-durometer rubber, those.
If not, see if Moog lists hi-dur rubber (they did years back for some GM apps; no idea if that's current.)
I like the GW Del-A-Lum otherwise.
Old Apr 2, 2015 | 06:58 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
Global West Del-A-Lum bushings are hands down the best.
Old Apr 2, 2015 | 06:59 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Im going with MOOG regular replacement rubber bushings. Fits my needs/wants the best.
Old Apr 3, 2015 | 10:01 AM
SOCAL-Z's Avatar
Car: 87' IROC
That's what many guys have told me. LOL
Old Apr 3, 2015 | 10:19 AM
peterc005's Avatar
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
I like the Energy Suspension poly bushings. Replaced all suspension bushings and mounts with these units.
Old Apr 3, 2015 | 10:23 AM
SOCAL-Z's Avatar
Car: 87' IROC
Moog always sounds good for replacement parts.
Ed1LE
Sep 30, 2018 09:14 AM
no green
Jan 9, 2016 09:22 PM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
