POLL - Spohn Torque Arm Clunk / Noise / Loud?
Subscribe
View Poll Results: Does your Spohn Torque Arm make noise ?
Yes... that bracket that ties arm to crossmember is LOUD!
66.67%
Nope... seems like factory...
33.33%
Voters: 3. You may not vote on this poll
May 12, 2015 | 08:08 AM
I've seen / read many threads... many have noise... many don't... but what is the ratio...
Sadly, I'm on the "has noise" side...
91 5.0 TPI Formula 5 Speed.
Spohn & Alston Sub frame connectors.
Bilstein Struts and Shocks.
All Poly engine mount, sway bar bushings & ends, Trans mount without plate...
Global West Del lum A arm bushings
Moog Stock Height Springs...
Freshly rebuilt 10 bolt with premium parts
Freshly built Astro A5 (T5) with upgraded main shaft
New Slip Yoke, custom drive shaft and new ujoints...
Pinion angle set to -1 as requested by spohn...
Second Skin Audio all over floor / trans tunnel...
New Founders 3 way ploy LCA's and Panhard Bar
Wonder Bar
Jamex STB
& still... clank, clank, clank...
I seem to hear it most while idling at speed, when I'm not pressing the throttle...
I love how it makes the car handle / feel... but that noise...
Mechanic said they pushed the fuel line bracket back... But I have no GoPro to check...
Reply 0
May 14, 2015 | 08:40 AM
Re: POLL - Spohn Torque Arm Clunk / Noise / Loud?
62 views, no votes...
Another note...
The bolts used aren't exactly right... part of the threads are inside the cylinder, and a couple of people have changed those, but for one guy I read, it was a bit better... but still made noise...
Any other solutions?
Reply 0
May 14, 2015 | 10:23 AM
I have the torque arm but cant comment on how noisy it is due to how noisy my car is in general. But I dont think i hear the sounds youre describing. Is the front mount on yours (the part that connects to the trans x-member) a steel rod end?
Reply 0
May 14, 2015 | 10:26 AM
Poly Mount to bracket....
Top is torqued to 100 ft.lbs.
Bottom to 50 ft.lbs per Spohn instructions...
It's not just one loud clunk... it's constant rattle when either not accelerating or braking...
Reply 0
May 14, 2015 | 10:43 AM
Maybe i do have that sound. I guess its coming from the back rod ends on the adjustments then. If you could replace those with a softer joint, i bet that would go a long way in silencing that sound.
Reply 0
May 14, 2015 | 10:45 AM
The back? Where the "adjustment" is?
It has lock nuts on it... I hear it just by my shifter.... I'm pretty sure it's the part that bolts the arm to the cross member...
Reply 0
May 14, 2015 | 10:48 AM
You gotta play with the nut "tightness" on those front mounts to the cross member. Its gotta be loose enough to pivot but too loose and it clunks alot on decel
Reply 0
May 14, 2015 | 10:49 AM
Something like this looks promising:
http://www.speedwaymotors.com/Garage...rts,21289.html
Reply 0
May 15, 2015 | 08:05 AM
are you sure its not these?
Reply 0
May 15, 2015 | 09:56 AM
Those ends on the rear dont make the noise. Its def a common problem and its the pivoting arm on the front connection. If too loose it moves alot and gets annoying on decel
Reply 0
May 31, 2015 | 07:21 AM
Yeah I tried a new bolt but it's still clanking pretty hard.
Reply 0
Subscribe
