Strut Mounts Moog or Fouunders? Need Quick Answer!
Old Jun 13, 2015 | 07:20 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
A bit confused...
I read 1 place that the aftermarket Moog ones fit 82 to 86 and that you need a different retainer plate for 87 to 92 cars... But on the Spohn website, it says the opposite... Says aftermarket ones only fit 87 to 92 (I have a 91) and you need the Spohn plates for 82 to 86 cars?
Pleases answer quickly
I ordered some AC Delco ones... the left one made in China, bearing was good, the right one made in Taiwan, bad bearing, replaced and IT TOO had a bad bearing... sent both back and now Rock Auto is waiting to ship out 2 Moog ones... "Still in warehouse" won't ship til Monday....
If i need to spend another $35 on Spohn plates, then I think I should just get the Founders...
Stock Height, Street Car...
Thoughts?
Old Jun 13, 2015 | 09:28 PM
daferris's Avatar
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
Re: Strut Mounts Moog or Fouunders? Need Quick Answer!
If its a daily driver go Moog. I have founders and very happy with them you can get more caster with them for the track. BUT they have solid spherical bearing in them. Moog has it in a rubber cushion. Ride is harsher with founders. Since I track my car I am fine with that if was daily driving it not so much...
Dave
Old Jun 13, 2015 | 09:59 PM
luvofjah's Avatar
Thanks for the advice... I do prefer comfort over race.
Do I need the Spohn retainer plate for my 91?
Old Jun 14, 2015 | 07:12 AM
daferris's Avatar
You should be able to use the stock ones unless they broke... Assuming you are talking about the plate that. Goes under the fender with the 3 bolts to bolt the strut mount to. It is not a high stress item for street stock is more than good enough. The spring pressure is what is primarily holding mount to the fender. The plate with bolts only keep it in one place. Goes without saying will need frt end aligned once done. Check your drag link also it will wipe outout tires fast if worn. With a ruler at the tie rod if you can move it 1/8" or more with 25lbs of force replace it (per the helm service manual). Also if replacing it pay attention to the center link. The height of the drag link is adjustable from the flats under inner tie rod holes in the center link to center of the front LCA bushing bolt MUST be same ( Iroc's are 17mm) other wise your Ackerman angle will be wrong.
Old Jun 14, 2015 | 07:23 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
For those who may be unaware of the two versions of the retainers, here's what I discovered several years ago (Spohn should be giving me a kickback, post #19, lol). Especially note post #3:
https://www.thirdgen.org/forums/susp...elp-quick.html
JamesC
Old Jun 14, 2015 | 09:17 AM
luvofjah's Avatar
So to clarify, the aftermarket ones fit the 87 - 92 retainers...
JamesC, you have an 85/86 an got 88 retainers that fit...
I see that some now have a bigger hole / rectangel and may need a washer...
Ok, I'll stick with the Moog...
Thanks!
Old Jun 14, 2015 | 11:43 AM
JamesC's Avatar
To get the Monroes to fit, I needed the second version (87-92) retainer. The same retainer also fit my Spohn and my Founders strut mounts. Personally, I wasn't aware of any ride difference between the Monroes and the Spohn and/or Founders pieces.
JamesC
Old Jun 14, 2015 | 11:12 PM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
Spohn has the better design for retaining the bearing in the cup. Get them over the others mentioned.
DSE has the trick ones - for adjusting caster & camber independently. Most street machines won't need. If you like to tinker with settings (street->track->street) they're the ones to get.
Not only did I get the retainer wishbones, I also got the plates that they ship with the coil-overs - Added insurance.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
NORTz89
May 20, 2020 03:51 PM
redmaroz
Apr 25, 2017 07:14 AM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
