Sway bar sizes.
Old Sep 16, 2015 | 08:45 PM
J0386's Avatar
Car: 1988 formula firebird 350
Engine: 350 tpi
Axle/Gears: Bw 9 bolt 3.27
Sway bar sizes.
I'm wanting to replace the front and rear sway bar bushings on my 88 formula 350 and not sure what size to get, if anyone could point me in the right direction that would be great.
Old Sep 16, 2015 | 10:50 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: Sway bar sizes.
If you have a digital caliper check the swaybar at the thickest portion. Or, use a metric wrench and see which one fits over the swaybar. Or, check tour RPO code against the link below.
https://www.thirdgen.org/forums/faq-...-sway-bar.html
Old Sep 16, 2015 | 10:51 PM
Night rider327's Avatar
Car: 1988 Camaro
Re: Sway bar sizes.
Best way to find out what you have is to measure your bars. If you do not have a dial caliper you can use metric open end wrenches to find the size... Keep trying diff. sizes untill you get a good tight fit around the sway bar... That size wrench will be the dia. of your bar.
Or you can even use an adjustable wrench or vise grips and a ruler/tape measure, put it on the bar and tighten it down, remove with out changing the adjustment, then measure the inside of jaws... That is your bar size
Old Sep 28, 2015 | 11:47 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: Sway bar sizes.
You have WS6 suspension: 36mm front, 24mm rear
Old Oct 12, 2015 | 07:46 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: Sway bar sizes.
Once you measured...buy from top down solutions. lonsal is great to deal with.
Bought all my endlinks and bushings from him.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
