How many wheel chocks
Car: 1985 Camaro Z28 IROC
Engine: 5.0L TPI H.O. 215HP STOCK
Axle/Gears: GU6=3.42
Howdy all,
So I just received my Amazon packages and I will be darned if the wheel chocks that I order were only sold as a single. I have always used a 4x4 piece of wood in he past. So I would like to know, how many of you use a single wheel chock?
Car: check
Engine: check
Transmission: check
Re: How many wheel chocks
Depends upon what I am doing. It guess it is about 50/50 between using one and using two. If I'm lifting a single corner then one is usually enough. Lifting an entire end or side, most definitely I use two.
This also depends upon the surface and the slope of the surface the car is on.
RBob.
RBob.
Thanks Rob, better safe than sorry will problem just buy another one.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Flat surface I use one. If its angle ill use 2.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Engine: TBI,5.0
Yes, you can use one on end as a jack stand also
Just kidding with you man ........
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Depends on what I'm doing. If Im doing brake work on the rear, then two, if not just one with the ebrake on.
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
if i jack up the front, I'll use wheel chocks on the front of the rear wheels, and 2x4's behind.. This way there is zero front to back movement.
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
One 4X4, about 5" long will make 2 perfect triangular wheel chocks when split corner-to-corner along the grain with an axe. I find that wood grips a rubber tire better than any other material.
Depending on which end/corner is being jacked up, I usually use just 2 chocks front and rear on the same tire that's staying on the ground.
Thanks for the words of advice, I have a couple of 4x4's left from the fence build this summer, I will give it a try
