Adding Front Wheel Speed Sensors
Old Jan 17, 2016 | 06:05 PM
84LsxZ28's Avatar
Car: 1985 Z28
Engine: Turbo 5.3
Transmission: 4l80e
Axle/Gears: Ford 9"
I am going to try and utilize the Megasquirts traction control with my car but I have not really found much about adding the two front speed sensors to the thirdgen's assembly.
I read in another thread where you can use an S10 dust shield and rotors, though they didn't go into much detail about it, whether the S10 parts just bolt up or if I need to modify more things.
Are there any other ways that people have added speed sensors to the front that work better than s10 stuff?
Old Jan 17, 2016 | 06:08 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: Adding Front Wheel Speed Sensors
S10 rotors should work, but you'd need to figure out the mounting for the sensor.. which may be in the dust shield..
what are you doing in the rear? a 4th gen rear from a car with traction control would seem to be the easy way to do it..
Old Jan 17, 2016 | 08:13 PM
84LsxZ28's Avatar
Car: 1985 Z28
Engine: Turbo 5.3
Transmission: 4l80e
Axle/Gears: Ford 9"
I looked online and saw that the sensors were in the dust shield. Do the S10 parts bolt right on to the thirdgen spindle and hub?
I figured I could just use the speed sensor that's in my transmission tail shaft housing.
Old Jan 18, 2016 | 06:11 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Pretty sure the hub will bolt on, might need slightly different bearings.
the speed sensor in the tailshaft will not give you a wheel speed signal which is what u would need isn't it?
Old Jan 18, 2016 | 12:29 PM
novaderrik's Avatar
Car: 86 Camaro
the S10 used G body spindles, which are what the F body spindles were based off.. everything that bolts to the spindle: dust shield, rotor, caliper- is all the same between G bodies, F bodies, and S trucks... so following this logic, the S10 stuff will bolt right up to a Camaro. might be fun thing to experiment with in a junkyard before you buy the parts..
the only 2 wheel drive S trucks that used a different spindle were the 2000 or so and up models that had the bolt in bearing/hub assembly with a slip on rotor.
Old Jan 20, 2016 | 07:00 PM
84LsxZ28's Avatar
Car: 1985 Z28
Engine: Turbo 5.3
Transmission: 4l80e
Axle/Gears: Ford 9"
I was under the impression that I could by inputting the certain trans speed sensor and gear/tire combo. I'll have to look into that more.
Okay, great info, thank you. Seems like I'll get the s10 stuff when I get around to doing the brakes on this car.
ProtoMaster22
Dec 27, 2015 09:08 PM
1Aauto
Sponsored Vendors
Dec 21, 2015 02:40 PM
84 1LE
Dec 20, 2015 09:12 PM
jwstrand
Pacific Northwest Region
Dec 19, 2015 10:29 PM
mcgarnicle
Interior Parts Wanted
Dec 19, 2015 09:27 AM
