Are all stock sway bar end link bushings black?
I was just under my 87 IROC and saw that my bushings are red and don't look like they are made of regular rubber. Are the stock end link bushings always black?
Engine: 4++,350 & 305 CIs
Re: Are all stock sway bar end link bushings black?
generally
black is rubber base suspensions (can also get aftermarket poly in black)
yellow poly was factory ws6 until 90-91
91-2 ws6 went to blue poly.
red and other colors are aftermarket poly
Car: Used to be an '87 IROC
Engine: 5.7l TPI
Axle/Gears: 3:23?
As I recall, my '87 IROC had off white bushings and they seemed to be made of nylon, or something like that. When you say "poly", do you mean polyurethane, or something else? I find it hard to believe an OEM would install urethane bushings since they're so squeak prone.
Received 1,680 Likes
The ones on my 83 L69 were also the almost transparent yellowish poly.
No squeeeeeks that I can recall.
jeremy iroc z28
06-25-2016 01:34 PM
