Heidts and Alstons
Car: 1988 iroc-z (original owner)
Transmission: 5-speed manual
Heidts and Alstons
I first purchased the outer SFCs from Heidts, then a week later the inner SFCs (Alstons) also from Heidts. Both are bolt-on, and I had the intention of bolting them in and then next year possibly welding them. I got the car about 23" of the ground with redundant support: jack stands and cribbing. (All because a buddy died via a car dropping on him a few years back, and the incessant nagging by my older son and wife.)
I'll cut the post short and say that I decided that, instead of bolting them in and drilling into the floor board for the outers, I would just take them to a shop to get them welded. I did do a lot of the prep work under the car.
The ride is so much better, as everyone said it would be. Why didn't I do this 28 years ago when I bought the car?
Car: 1989 GTA
Engine: LS coming soon
Transmission: 80E coming soon
Axle/Gears: S60/35 Spline/S-Trac/3.73
Re: Heidts and Alstons
Very nice! Did you have them stitch welded on the outters or just the main points?
Just the ends are fully welded. I took it to www.big3racing.net and they said that they highly recommend NOT stitch welding along the rocker seem, which I had ask them to do. They reworked the exhaust around the cat to make enough room for the inner on that side.
It's a world of improvement. Not something that I could just bolt in, and not in the "four hours" as each set's instructions indicated.
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Where did you find these heidt connectors?
the outers, RC-536, are at http://www.heidts.com/part/rc-536-19...me-connectors/
the alstons are AL-102411 and are at http://www.heidts.com/shop-by-applic...92&c=32&show=0.
Engine: 4++,350 & 305 CIs
I'm guessing the outers stop before they get to the torque boxes in the front for the bolt on applications?
Welding to the rocker pinch weld is a good thing. May be harder with round tubing instead of the rectangle stuff.
The subframes are a huge improvement on these cars.
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
dennisbernal91z
Apr 14, 2016 05:42 AM
