Front end pop under breaking
Old Aug 8, 2016 | 03:55 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
I searched but couldn't really find the exact symptom. When I'm coming to a stop, I'm getting a pretty heavy popping noise from what appears to be the left front. This happens just as the car comes to the stop. Not during the application of the brake but just that final last push to bring it to a full stop. Speed is irrelevant as it happens from dead slow to highway speed. Not all the time but probably 80% of the time. I thought maybe it was the front pads but they'd already be in contact with the rotor as this happens at the very last moment of breaking. Turning does not matter either. It also sounds too heavy a sound to be a break pad. Almost sounds like a big spring releasing. I did check my front springs and they are not broken. Also had new ball joints and front end steering components replaced a month ago, but this sound was there before all that. Only happens during braking. Going over bumps or letting off the gas abruptly does not cause the sound.
Old Aug 8, 2016 | 05:05 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Re: Front end pop under breaking
Popped the front left tire off and found the outer pad flopping around excessively. Took it off and bent the ears, slapped some lithium on it and went for a drive. Noticeably better. Must be the right side that's loose as well. I didn't think such a small thing could make such a big sound, but I guess once you factor the load force that's involved and the fact it transmits through the frame like a microphone, it can be quite deceiving.
Old Aug 9, 2016 | 04:04 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Good to know. Thanks for letting us know what you found.
Old Aug 24, 2016 | 10:14 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
I'm starting to have this issue as well. Now luckily a buddy of mine went through this on another car so I sort of knew what it could have been. This sort of verifies it now lol, thanks. I'll let you know what I find this weekend.
P.S. I need to rebuild my front end soon ;P
Johnny Import
Apr 3, 2016 10:19 AM
gt4373
Mar 19, 2016 11:15 PM
That Sky Guy
Mar 15, 2016 07:40 AM
bad camaro RS
Aftermarket Product Review
Feb 26, 2001 08:18 AM
Slow-LG4
Oct 31, 2000 10:19 PM
