QA1 ball joints
Old Feb 19, 2020 | 08:33 PM
  #51
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: QA1 ball joints
These fit pretty good.
https://www.ebay.com/itm/15179731681...m=151797316815
Old Feb 21, 2020 | 05:34 AM
  #52
rgauder's Avatar
Car: 1987 Trans Am
Re: QA1 ball joints
Will these fit the extended balljoints without tearing?
Old Feb 21, 2020 | 09:50 AM
  #53
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Re: QA1 ball joints
They fit fine when I tried them, I also have the extended qa1 balljoints, but I didn't install them. So only trial fit them.
Old Mar 31, 2020 | 08:58 PM
  #54
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: QA1 ball joints
I installed Proforged +0.5" K6145 equivalent balljoints on a vehicle and had the following measurements on their included boots 1.803" i.d. 1.482""ht. 0.8" opening
Old Apr 1, 2020 | 05:52 PM
  #55
skinny z's Avatar
Re: QA1 ball joints
Did a quick web search and could only come up with Proforged's traditional offering. Do you have a specific part number? I came across a K6145T however there were no specifics given (although I could see how the "T" indicates "tall").
Old Apr 1, 2020 | 06:29 PM
  #56
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Re: QA1 ball joints
PF tall ball joint # is 10048, summit has em.
Old Apr 2, 2020 | 04:41 PM
  #57
jmd's Avatar
jmd
Re: QA1 ball joints
T is a Moog part suffix indicating improved design. The K6145 was a press-fit design of course. The K6145T is the same length but adds knurled increased outer diameter. It may have had other updates. I necro bumped the thread because I made an effort to find poly boots a year or so ago.
Old Apr 2, 2020 | 07:36 PM
  #58
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: QA1 ball joints
For what it's worth, the Howe ball joint has a replaceable stud that you can service without removing the housing from the a-arm. That's kind of sweet.
Howe part numbers
22494......... housing
22429S...... +0.75 longer stud
22399V...... viton boot
Old Apr 3, 2020 | 10:51 AM
  #59
soloc4's Avatar
Car: 84 Z28, 92 C4 suspension F&R, ABS
Engine: 408 LS2, CNC LS3 heads, Comp Cam
Transmission: Magnum F, RTX clutch, Tick shifter
Axle/Gears: DANA 44, Tru Trac, 3:73 gears
Re: QA1 ball joints
Howe part numbers
Agreed, I used the Howe ball joints on my build. They are the only ones that have +1” lower joints for a C4 front suspension, but they (Howe) have joints for most popular cars with multiple pin heights for whatever you need. I love the fact that you can service them without having to press out the housing.
Old Apr 3, 2020 | 04:31 PM
  #60
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: QA1 ball joints
Yep, and if you decide you want a different height then just swap out the stud with basic hand tools. But they don't hold much grease so you want to check it with every oil change.
Old Apr 9, 2020 | 12:48 AM
  #61
SlickTrackGod's Avatar
On Probation
Re: QA1 ball joints
I rarely come in here anymore unless someone asks me to check out a thread. Saw this thread popped back up from 2016. Ironically in 2018 I picked up a 2wd Chev S10 and modified it- lifted it aprox 4" and reinforced the truck to carry more weight, as well as larger tires for safety- stock skinnies were scary as all heck in the rain, especially with a load in the bed.
I ended up using the QA1 1" extended ball joints and after two years they are great. This little truck actually handles pretty good considering its lifted and not made for that. I used Viking double adjustable hybrid coilovers (coilover on bottom and fits into the spring pocket up top- very nice setup.) The adjustable ball joints are very nice units and I have yet to have to "tighten" the adjustment even with the abuse and weight I toss at his truck daily. Much nicer units then the old Coleman monoballs.
This was it stock, pathetic.
I also built panhard rod with adjustments onto it because of the heavy loads. The leaf springs alone were not handling the side loads.
Trust me the QA1 balljoints take abuse. I abuse this thing more than an Enterprise rental car.
Old Apr 9, 2020 | 01:01 AM
  #62
On Probation
Re: QA1 ball joints
Haven't posted here in awhile. Came in to look at another post and saw this old thread popped up from 2016.
Ironically on the subject of QA1 ball joints, I built an S10 truck in 2018 (same lower a-arms as 3rd gens) and used 1" extended QA1's on it. This was the truck when I got it in stock form.
Felt like a kid's truck, needed to beef it up to carry heavy loads and make it more manly. Added Viking hybrid coilovers and lots of modified goodies completely re-working the front suspension geometry. (Note again these A-arms will fit 3rd gens.)
Lifted it 5"/4"
Also ironically I built a rear panhard setup for it too
Trust me this thing gets more abuse then an Enterprise rental car. Balljoints are extremely solid pieces and take tons of abuse.
Old Feb 18, 2022 | 07:16 AM
  #63
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Re: QA1 ball joints
I think I'm gonna go with the QA1's 1210-209P ball joints and I'm interested in hearing about how these pressed into the lower control arm. According to QA1 the OD is 2.000" and I'm measuring 2.080 on my factory control arms, doesn't seem like much of a interference there. Since these are rebuildable I really don't have a problem with welding these in.
The only other options I'm seeing for a pressed in fit are the Moog K6145T standard height ball joint or the Proforged 101-10048, +.500" taller ball joint, both from what I've found supposedly measure at 2.100"
Old Feb 18, 2022 | 07:56 AM
  #64
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Re: QA1 ball joints
You may already have oversized ball joints installed on your a-arms. If so, (and as far as I know) qa1's do not come in oversized version. How would you weld aluminum ball joints to steel a-arms anyway?
if you do have oversized ball joints, moog or pro forged are good options.
Old Feb 18, 2022 | 08:17 AM
  #65
91banditt2's Avatar
Engine: 5.7 HSR
Re: QA1 ball joints
I wasn’t aware they were aluminum 🤦🏼 I wonder if QA1 at some point made these in steel I say that because a member here McLovin1181 3rdgenguy on YouTube welded a set of QA1 ball joints to his stock control arms, might be worth calling QA1 to see if a steel ball joint is available.
Edit: Looked through his Instagram because I vaguely remember having a discussion about these, I’ll call QA1 today
Edit #2: Spoke to a rep for QA1 and was told that the 1210-209P ball joint is steel not aluminum.
Old Feb 18, 2022 | 10:38 AM
  #66
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Re: QA1 ball joints
Well that's what I get for assuming. Those damn things looked and felt like aluminum. Shoulda put a magnet to them.
What about the o.s issue?
Old Feb 18, 2022 | 10:49 AM
  #67
91banditt2's Avatar
Engine: 5.7 HSR
Re: QA1 ball joints
o.s issue?
Old Feb 18, 2022 | 11:00 AM
  #68
91banditt2's Avatar
Engine: 5.7 HSR
Re: QA1 ball joints
QA1 does offer a dust boot part# 9034-107, where these not offered back in 2016?
Old Feb 18, 2022 | 11:52 AM
  #69
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Re: QA1 ball joints
Originally Posted by 91banditt2
o.s issue?
Oversize
Old Feb 18, 2022 | 12:12 PM
  #70
91banditt2's Avatar
Engine: 5.7 HSR
Re: QA1 ball joints
Oversize
According to QA1 the portion of the ball joint that presses into the control arm is 2.050 but for what ever reason their website states 2.000, either way they'll need to be welded to my control arms, again since they're rebuildable I'm ok with that.
Old Feb 28, 2022 | 12:04 AM
  #71
McLovin1181's Avatar
Re: QA1 ball joints
The Qa1 ultimate Ball-Joint should be 2.090-2.092in
I've installed 4 of them so far and they always end up within that range.
As far as a press fit, they will be loose in a factory A-arm because the stock Ball-joints are knurled.
You should absolutely place some tacks under the Ball-Joint after you press it in.
If you intend to weld them in, REMOVE the guts of the QA1 ball-Joint. Only have the metal threaded installed disk installed to avoid any warpage.
And yes, the Ball-joint body is steel.
I assume stainless as they don't rust.
Use dust cover:7219034107 with the QA1 joints
A 1/2-3/4 in long piece of rubber tubing may be needed to keep the dust boots seated.
I think I used some 5/8 fuel line chopped to 3/4in long.
they have 3 stud lengths, anything longer stock needs a bump steer kit otherwise bump steer becomes atrocious.
These Ball-joints have to be serviced once a year/race season so keep that in mind.
​​​​​And that means serviced/checked without the spindle attached.
I also have a video on the rebuild.
it's not hard at all.
Little messy though.
https://m.youtube.com/watch?v=mG22bQ1YT_I
Old Feb 28, 2022 | 04:02 PM
  #72
91banditt2's Avatar
Engine: 5.7 HSR
Re: QA1 ball joints
Do you mean 9034107?
Old Feb 28, 2022 | 07:13 PM
  #73
Re: QA1 ball joints
I have 2 spare dust boots and that's what the lable says.
I know there's a QA1 dust boot and an energy suspension part.
I assume it's the same part with a different part number.
TonyC
Aftermarket Vendor Review
Jan 20, 2012 01:26 AM
FordGirlGoneBad
Mid-Atlantic Region
37
Jun 3, 2011 07:58 PM
IROCThe5.7L
Mar 22, 2005 06:18 PM
Dragons91RS
May 27, 2003 12:40 PM
crazynights
Feb 20, 2003 07:41 PM
