track bar 4th gen
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
track bar 4th gen
Are third and fourth gen track bar the same. Many of these third gen have bolts that are seazed up and got a cut the bolt. If fourth are the same that would be nice
Re: track bar 4th gen
Yes they are the same. The bolts are also the same.
Personally I wouldn't put a junkyard Panhard bar on my car whether off a 3rd or 4th gen, or even a new OE one; but the bolts, used ones are fine.
Car: 87 Trans Am
When I pulled my panhard rod off to do the 4th gen tank install I noticed my bolts were deeply pitted along the shank, so I came across a 4th gen in the junk yard and took those bolts since they are actually tapered and I haven't found replacements online. Same bolt.
Axle/Gears: 273?277
I see no menchen of a panhard bar in the manual. But I've noticed the lower track bar is refers to as such. My upper bar is the one I needed. I got both and compaired them and decided 15.00 was OK for both with bolts like new off a 4th gen. Now the gas tank and straps look like they would work.will they? The after market pan bar,how much they run. What's wrong with stock for a daily driver?
Is that what YOU want under YOUR car? Not me.
Axle/Gears: 273?277
How much do the aftermarket cost? I got a admit there are some very good upgrades for our cars out there. Now I've got a body or two worth fixing up,I may start looking into them.
https://www.foundersperformance.com/.../panhard-rods/
dennisbernal91z
Fabrication
25
Mar 20, 2017 08:42 AM
Arctic White 91 RS
Convertibles
Jan 9, 2017 09:16 PM
edpontiac91
Oct 8, 2016 06:26 PM
formula1LE
Sep 27, 2016 09:56 PM
RABMAN
Sep 25, 2016 10:44 AM
