Why Is My Car Leaning On The Drivers Side?¿
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
Hey Guys, my car was leaning on the drivers side, I put new Shocks, Struts, Springs, Alignment, and Tires and it is still leaning on the drivers side $1100 dollars later. Not quite as bad as before, but definitely noticeable. This is pissing me off. The car was never wrecked, except a very minor hit on the drivers side front fender (Which was changed) The damage didn't even hit the door or the hood, it was very minor. Could it be a body mount?? Does this car even have body mounts? I have no Idea why it does this. Anyone else have this problem?? Any help would be appreciated.
Mike
Mike
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No body mounts, the subframes are all welded to the body. Maybe the spring isolators on that side?
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
I agree, check the spring isolators and also check to see that the springs are positioned correctly.
The tails of the front springs should stop on the inside of the front A-arms and be positioned so they cover the first drain hole and partially cover the second. If your springs don't line up this way then they're not installed correctly.
Engine: ZZ4 - 350
Thaks Guys. the springs are correctly installed, and I have changed all the bushings in the front and back - swaybars, etc. What are spring Isolators?? I will have to check that.
Thanks again.
Mike
Thanks again.
Mike
Car: Yes...
The spring isolators are the rubber pads that should be on top of the springs where they contact the body/frame of the car.
If one is missing or out of position that could cause the problem you're having.
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Mutillator
Oct 1, 2015 06:05 PM
