New bump stops from Hawks
Old Nov 5, 2016 | 06:04 PM
85projectZ28's Avatar
Car: 1985 Camaro Z28
Engine: 5.7 LSX
Transmission: Performabuilt 4L60E
Axle/Gears: Strange 12-bolt 3.73
I cleaned up the underbody, and put a new fuel tank, pump, and sending unit. While I was under there, I saw how gross the stock bump stops were. I checked around and found some nice ones on Hawks Motorsports for $99.95. Here they are next to the originals. Only problem is, they are about half an inch bigger/taller than stock. I hope this is not an issue as I will be lowering the car 1-2". Anyways, here are some pics.
Before.
After.
I think that little bit of red against all that black and silver really makes it pop just enough to look great.
Old Nov 5, 2016 | 07:25 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: New bump stops from Hawks
only odd part is that is the only part you haven't cleaned yet? scrub, black paint, done...
Old Nov 5, 2016 | 08:33 PM
BrutalGTA's Avatar
Car: 1989 GTA
Engine: LS coming soon
Transmission: 80E coming soon
Axle/Gears: S60/35 Spline/S-Trac/3.73
Old Nov 6, 2016 | 07:29 AM
Engine: 5.7 LSX
And keep those old ones? No way. I did remove them to clean and paint the underside, but once it was all done, the old ones looked terrible back on. Also, they were rubber. I wanted something new and preferred polyurethane.
Old Nov 6, 2016 | 10:42 AM
BrutalGTA's Avatar
Car: 1989 GTA
Cleaning the rubber and maybe some touch up paint on the metal should have them like new. Your probably going to have to trim the new ones with the drop.
Old Nov 6, 2016 | 07:56 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
According to Herb Adams, the bump stops are tuned as part of the spring package on the cars. They can be changed, height, width and angles to make it hit slower or harder or faster. Crazy the stuff that's in his book..
Old Nov 6, 2016 | 09:04 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
polyurethane will be like hitting a metal bump stop, not a good cushion, and lowered, your gonna hit those...
Old Nov 6, 2016 | 09:18 PM
t/aws61985's Avatar
Car: 85-6 TA 85 IROC 82-86 MSE 83 Pace
Engine: Slow ones
Transmission: Noisy ones
Axle/Gears: Weak ones
I was also contemplating buying these. They have been in my eBay cart for like 5 months now. Dont know if i can justify spending $100. I don't see them worth more than $50. for the hight issue. You could probably just take a grinder and file that bracket down.
Old Mar 31, 2018 | 09:08 AM
SirReveller's Avatar
Car: '89 'ROC
Engine: 5.7L
Agreed- if these were $39.99 there’d probably be a lot more posts about them. $100 before shipping is beyond the beer money “sure” realm of spending. They do look sharp though, 85, so props to you there. How have they been drive-wise? Even notice a diff?
Hawks as usual does not explain any performance benefit, aside I guess from singing the praises of poly.
http://www.hawksmotorsports.com/bump...acement-82-02/
I also assumed these would bounce your head off the roof if you took a speed bump way too fast vs rubber (or more accurately old AF semi-deteriorated rubber) but interestingly here the guy notes these poly bumps supposedly ”reduce rebound forces.”
http://www.camarotech.com/suspension.html
Old Mar 31, 2018 | 10:34 AM
Drew's Avatar
Old Mar 31, 2018 | 10:40 AM
Car: '89 'ROC
Engine: 5.7L
Lol - Drew I take it from your gales of laughter this dude is dead wrong?
Old Mar 31, 2018 | 12:36 PM
Drew's Avatar
I've never seen a set of rear bump stops that were worn out. A squirt of Bleche-Wite followed by a light old-toothbrush scrub would take the brown oxidation off those old bump stops. I mean the steel isn't even rusty...
^^^ This is a gut-buster. ^^^ It reads like the sheer thought of using an insignificant, used part is just horrifying.
Then this part. If dog **** were billet aluminum and red poly, this dude would buy it. If I won the Mega-Millions jackpot, I wouldn't buy crap like this.
Something, something, a fool's money...
Old Mar 31, 2018 | 01:06 PM
Car: '89 'ROC
Engine: 5.7L
Lol- we’ll at least allow the dude that it looks sharp! :P
Drew, challenge question: if the OE rubber bumps never deteriorate how come there’s the $8 Dorman replacements etc?
Old Mar 31, 2018 | 01:13 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
polyurethane will be like hitting a metal bump stop, not a good cushion...
Yep. I had poly on the front briefly. Hated it.
JamesC
Old Mar 31, 2018 | 01:44 PM
Drew's Avatar
Whoa! I didn't say 'never deteriorate', I said I'd never seen a set that were worn out.
You'd have to ask Dorman, but I'd assume they're not application specific, and...
People do some crazy stuff. I'm sure they can be abused into submission.
Old Mar 31, 2018 | 02:08 PM
Car: '89 'ROC
Engine: 5.7L
G body, yo.””
Gotchya. Still think they look cool tho :P If it were a real “upgrade” ES would probably have a pair. BTW James C thanks for all your posts over the years. Many have been quite helpful.
Old Mar 31, 2018 | 03:18 PM
JamesC's Avatar
JamesC
Old Mar 31, 2018 | 03:23 PM
t/aws61985's Avatar
Engine: Slow ones
I actually ended up finding a set on ebay for like $65. I have them on my car now.
Old Apr 1, 2018 | 01:08 PM
Erik Woods's Avatar
Car: 92 IROC-Z
Engine: 5.0
Transmission: 5 Speed Manual
I usually avoid Hawks, but was considering getting these. Glad to see it's completely unnecessary.
Old Apr 2, 2018 | 09:04 PM
NoEmissions84TA's Avatar
https://i.ebayimg.com/images/g/5rcAA...Am/s-l1600.jpg
You paid an extra $80.00 for those aluminum spacers!
Old Apr 2, 2018 | 09:25 PM
Cut the tab off, or bend it up 90 degrees out of the way.
https://www.summitracing.com/parts/ens-9-9137r
https://forum.ih8mud.com/threads/200...-stops.684295/
http://www.camarozone.com/forum/f20/...-stops-111050/
https://ls1tech.com/forums/suspensio...-approach.html
https://ls1tech.com/forums/suspensio...ump-stops.html
