4th Gen rear swap question regarding E-brake cables
Old Feb 13, 2017 | 10:49 AM
Falconiroc's Avatar
Car: 1991 RS
Axle/Gears: 4.11
I am purchasing a 1991 RS with 4th Gen rear in it. I swapped a 4th gen rear into my 88 IROC, but I don't remember the solution I used for ebrake cables. Can you use stock ebrake cables, or re-use 4th gen cables? (this doesn't come with either, so I'll have to source some).
Old Feb 13, 2017 | 12:44 PM
daferris's Avatar
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
Re: 4th Gen rear swap question regarding E-brake cables
I used 4th gen ones on my '88 then made 2 about 10" long extensions to reach the center cable
Old Feb 13, 2017 | 09:02 PM
881le2b's Avatar
use 92 z cables with disc brakes, they offer two different lengths! Forget the #'s but it's the shorter one! 1456cm or something like that! Have a 2k axle in mine! Love it!!
Old Feb 13, 2017 | 09:19 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
Good to know. Would be nice to have an e brake again myself. Maybe somebody can chime in the exact length cables needed.
Old Feb 13, 2017 | 09:20 PM
Falconiroc's Avatar
Car: 1991 RS
Axle/Gears: 4.11
Thank you!
Old Feb 22, 2017 | 07:16 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Hawks sells proper conversion cables
Old Feb 23, 2017 | 01:15 PM
Falconiroc's Avatar
Car: 1991 RS
Axle/Gears: 4.11
I purchased some Cables that I believe are the correct cables. I'll be installing them this weekend.
Old Mar 16, 2017 | 02:11 PM
Falconiroc's Avatar
Car: 1991 RS
Axle/Gears: 4.11
Ok the cables I got were too long, The Covered portion was ok. I had to modify the Caliper end of the cable so that it would slip over the lever arm, and then I had to put new cable stops on the other end so that it would engage the equalizer at the right point. I may need to put a better stop in when I find one, but they are working currently.
Old Mar 16, 2017 | 10:12 PM
Wickydooda's Avatar
1989 Firebird Formule 350 with a 10-bolt rear end out of a 99 Camaro SS.
I used two "Tru-Torque #C94597" e-brake cables, ordered through my local Advanced Auto. The only alterations I had to do was simple stuff. Took a Dremel and widened out of the little bracket that connects to the rear brake "hook" (you'll see what I'm talking about upon closer inspection. Really not a tough thing to replace, just takes a small amount of patience.
They are functional now, but my only complaint is that you really have to pull the ebrake handle up a LOT to get them to engage. I'm sure I can adjust that a little bit by rigging up the cable a bit, but I'm not too worried about it because they still engage (plus it's an automatic).
The thread I referred to during my installation was the following: https://www.thirdgen.org/forums/faq-...-gen-rear.html
Old Mar 28, 2017 | 09:30 PM
Falconiroc's Avatar
Car: 1991 RS
Axle/Gears: 4.11
Wickydooda, yea I pretty much have the same situation with mine, though I cut the ends off and put some new ends on but did not secure them enough so I'm going to have to re-do it. I also had to widen the bracket with my dremel. Sounds like I'm running into the same stuff as everyone else =)
Old Mar 14, 2024 | 12:23 PM
MaroMobito's Avatar
Thank you for this! I was able to call Hawks and get these.
Hawks Part number HT-SR047-56 For anyone interested.
1 x 82-92 LS1/LT1 Rear End Swap E-Brake Cables Pair
Old Mar 14, 2024 | 01:51 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Let us know how they work out. I bought the hawks cables a few years ago and never could get them installed as they appeared to short.
