Loose subframe bolts
Old Mar 14, 2017 | 10:49 AM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
I'm not sure who did what to the car I just bought, but most of the front body panel bolts were lose so I tightened them up.
Last night, doing motor mounts, struts, etc, I notice one of the big carrier(?) to subframe bolts was loose. The one just above the rear lower control arm pivot bolt. I torqued it to about 100 lb-ft but couldn't find a torque spec.
I checked others, they seemed fine.
Is this typical for these cars or perhaps someone was careless with some refitment?
Old Mar 14, 2017 | 01:17 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Re: Loose subframe bolts
Hard to say. Iv changed some subframes in newer cars and have seen bolts missing! Maybe a defect from the factory or someone else has been into the car? With the age I'd go with someone being careless.
Old Mar 14, 2017 | 02:10 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
They are k-member bolts, our cars don't have a sub-frame. Here are some links to short threads with good info on the location of and the torque spec of those bolts:
https://www.thirdgen.org/forums/susp...passenger.html
https://www.thirdgen.org/forums/susp...-k-member.html
https://www.thirdgen.org/forums/susp...our-front.html
RBob.
Old Mar 14, 2017 | 04:30 PM
Engine: 350 TPI L98
Transmission: WC T5
Thanks, I noticed many commented that the third post should be a sticky. I agree!
Old Mar 14, 2017 | 07:50 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Where did that graphic come from? 160 N-m is standard torque for a 14 mm bolt.
The K-member bolts on my '89 are M12 and a bolt of that size has a standard torque of 100 N-m, and a high torque of 105 N-m for structural members. Coincidentally (or not so coincidentally), the GM service manual for an '88 Firebird (the only version I can find) calls for 105 N-m torque.
Old Mar 14, 2017 | 08:42 PM
Engine: 350 TPI L98
Transmission: WC T5
89 Service Manual
Old Mar 14, 2017 | 08:55 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I'd pull a bolt and measure the thread size. If it is an M12 then throw all of them in the trash and buy new bolts, and then torque it properly.
