Anyone see a way to save some money on front end rebuild?
Old May 24, 2017 | 07:22 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
Hey guys, I've been neglecting my thirdgen for a while now and putting all my money into my jeep. I really want rebuild the front end steering and suspension since I redid the rear suspension last summer.
here's the parts list I have going so far on rockauto..
I Still have to buy new struts, sway bar end links, and a couple other things as well that's not listed. does anyone see a way to save some cash with that list? thanks.
Old May 25, 2017 | 01:16 PM
Re: Anyone see a way to save some money on front end rebuild?
This is a 3rd generation Camaro/Firebird message board.
That said, parts cost what they cost. RockAuto is about as reliable a source of the right parts at the right price as anybody. You might beat em if you pound the pavement hard, but they're not too far out of line.
Beyond that, DO THE WORK YOURSELF (while not screwing it up or cutting corners) is the best remaining way to minimize $$$$ outlay.
For a Cheeeeeep, check 4wheelparts.com, orw.com, even summitracing.com, etc. for competitive bids.
Old May 25, 2017 | 01:25 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Try Amazon. They sometimes have great prices.
Old May 25, 2017 | 02:09 PM
J. Chris Davis's Avatar
I just changed out all of my steering components except for the steering gear box. Summit Racing ended up being the cheapest with Moog parts rather than my local places like NAPA, Oreilly's and Autozone. I don't remember if I priced with Rockauto.
Old May 25, 2017 | 02:35 PM
TylerSteez's Avatar
Engine: 383 stroker
My car has never seen the insides of a shop since I owned it so no worries there..
ill price it all out on summit and amazon. Just trying to free up some extra coin. Thanks guys
Old May 25, 2017 | 02:38 PM
TylerSteez's Avatar
Engine: 383 stroker
Did you think I was trying to get jeep help on here? This is for my 86 trans am lol. I meant that I felt bad for putting all the money into my jeep lately so I want to redo the front end on my trans am
Old May 25, 2017 | 06:44 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Are all the parts in need of replacement?
Watch the drag link threads here on third gen. There were some on the aftermarket that weren't correct.
Old May 25, 2017 | 06:54 PM
TylerSteez's Avatar
Engine: 383 stroker
I saw a thread about that not having the correct angle, it was a MOOG part if I recall correctly. Im gonna do more research before I finally place the order, thanks for reminding me
Old May 26, 2017 | 08:02 AM
I'm using the Moog drag link with no problems. Looked just like the one I took off of the car.
Old May 26, 2017 | 08:26 AM
Jorlain's Avatar
Car: '84 Trans Am
Engine: 357 SBC
Axle/Gears: 10 Bolt 3.73, Torsen Diff
If you're replacing the strut mounts, you may want to consider aftermarket pieces, since it's not all that much more expensive.
https://www.foundersperformance.com/...-strut-mounts/
Otherwise RockAuto is about as good as it gets for most pieces. Summit might be cheaper due to the free shipping. Make sure to find a 5% RockAuto code while you're comparing.
Old May 26, 2017 | 07:22 PM
The part that people have been getting versions of that are wrong sometimes, is the idler arm. Which by being wrong ends up locating the center link at the wrong angle. (not level)
I've never had that problem myself but others it seems are finding it very commonplace.
Old May 26, 2017 | 09:56 PM
I did get the correct Idler arm with my Moog stuff. It is a little beefier than the one that was on there.
Old May 30, 2017 | 08:05 AM
Southernmost's Avatar
Car: 1984 Camaro Coupe
Engine: 305 w/ q-jet, Stock engine
Transmission: Stock 700R auto trans
Axle/Gears: Stock
I am in the middle of my front end rebuild and what I do is pull up rockauto to look up parts and cost. Then compare Amazon, Napa, Oreiley's, etc ... for the best price. Found Moog strut mounts for 1/4 the cost on Amazon with free shipping. Just have to search...
