What springs do YOU have on YOUR car???
Old Jan 3, 2002 | 03:18 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
What springs do YOU have on your car? What are the pros and cons of each brand? Anyone have any problems? I'm thinking about getting springs because they are some of the more inexpensive mods you can do to the car. Anyone??? I think I'd get the Eibach Pro-Kit, but I've seen some pics of the Sportline and they look killer( RSpeed ) Would the sportline look a little odd with 16x8 IROC wheels? I'm thinking the car wouldn't look right with such small wheels and lowered that much. Anyone happen to have pics of the Sportline's with 16inch wheels? Thanks.
Old Jan 3, 2002 | 03:52 PM
5 litre eater's Avatar
Car: '84 Trans Am
Engine: 350ci Sportsman heads, B&M blower
Transmission: Turbo 350
Do you mean lowering springs or weight transfer springs?
Old Jan 3, 2002 | 04:11 PM
Hg's Avatar
Hg
Car: '87 Z
Lowering
Old Jan 3, 2002 | 08:22 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
All being well I expect to replace the shocks, struts and springs this summer as well as add subframes and the global west stearing brace which I have but still need to modify so that it will fit my 83 TA.
I'm fairly sure that I'll get the global west springs because they are linear as opposed to the progressive type and they only lower the car about one inch which I think is enough.
Old Jan 4, 2002 | 08:12 AM
Dragula's Avatar
Hotchkis springs and rear suspension package.
Old Jan 4, 2002 | 09:57 AM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
I'm using the Ground Control ride height adjusters with a 175 lb/in springs in the rear. I already have the adj panhard rod from Spohn with poly/rod, his weldin SFC's and Tokico rear shocks (also from Ground Control) and Spohns adj LCA's.
The front is going to get the 5 way adj Tokico struts, adj weight/height jacks on the springs and upgraded bushings. I already have the factory wonderbar. (picked that up at Hawk Parts, listed here as a supporter) The front springs will probably be around a 290 - 340 lb/in rate. I haven't worked that out, yet.
Old Jan 4, 2002 | 12:43 PM
TVP's Avatar
TVP
5.5" "NASCAR" springs ..still waiting on GC to make me a set
of weld in weight jacks :\ they are a FULL 3" shorter than
stock .. really need those weight jacks !!!!!!!! been waiting 3 months !! getting as bad as the missing 1LE brake cradle !!!
TVP
Old Jan 4, 2002 | 12:50 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Hotchkis (1" drop) springs.Better ride than stock and way better handling,looks good too.
Old Jan 5, 2002 | 04:05 AM
Jza's Avatar
Jza
pro-kit
Old Jan 5, 2002 | 08:53 PM
fbodyfreek's Avatar
springs
i am currently using pro-kit springs and am very pleased.
Old Jan 6, 2002 | 09:56 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I'm using Hotchkis springs and Bilstein struts/shocks.
Old Jan 7, 2002 | 06:05 AM
espirocz's Avatar
Car: CTS-V & 89 Z28 vortech charged
Engine: LS6 & 383 charged stroker
Transmission: 6-speed & 5 speed
i have Eibach Sportlines with factory 16's. It does look good and handels even better. I'll try to attach picture.
Espirocz.
Old Jan 7, 2002 | 06:08 AM
espirocz's Avatar
Eibach Sportlines.
Old Jan 9, 2002 | 12:04 AM
SpeedCat86's Avatar
Car: '86 TransAm WS6
Transmission: Custom TH700R4
Did any of you guys go to aftermarket springs from a factory WS6 or equivalent suspension? I want to go to Tokico 5-ways and a keep the ride height close to stock so I don't put my deep pans and 3" pipes at risk. (possible upgrade to tubular A-arms and K-frame, too)
espicrocz: Nice ride, man! I love the stance, shoulda come from the factory like that.
Old Jan 9, 2002 | 08:57 PM
espirocz's Avatar
Thanks, SpeedCat. I make excuses to leave the house and run errands during the summer. This car is FUN to drive, I had a buddy autocross with me last summer. After the event he swore off front wheel drive cars. He said after driving my car, they had now become boring.
The only thing I have ever drug on the ground is the front lower chin spoiler, and it mainly only does leaving the driveway down the curb to the street.
Espirocz.
Old Jan 11, 2002 | 04:20 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
I'm running Jamex springs with full Steve Spohn adjustable suspension.
Old Jan 11, 2002 | 08:17 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Jamex was a reasonably priced spring and good performer. But they've virtually abandoned the US market. They closed their Reno NV wherehouse and are concentrating on the European market. I HAD Jamex on order, but was about a week too late. I bought Eibach Pro-Kit instead.
Old Jan 11, 2002 | 08:44 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
I run heavy front springs and light rear ones in my Camaro, good for a higher powered car.
Front: Guldstrand Slalom Springs cut 1" (about 725lb-in)
Rear: GC adjustable spring kit with 150lb-in springs
Rides decent and still hooks well.
Oh yeah, Bilstein struts and shocks too.
Old Jan 12, 2002 | 01:35 AM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
Im using the intrtax springs..their a progressive spring 550-720 sumthing up fornt..cant remeber the rear but much stiffer then stock. Im also using Koni reds at all 4. I must say the car handles like its on rails, but the ride quality isnt exactly anywhere near a cadillac, but I prefer a suer stiff ride as oppsed to a soft mushy feel...to see my install go to he website (iroczone) in my sig and look under tech articles to see them...
Old Jan 12, 2002 | 03:11 AM
BigMike 92 Z28's Avatar
I have eibach sportline lowering springs in the back, and lowering springs off my buddys 95 impalla ss. I dont know the brand of them and either does my budy. I did this and then cut them down a little. I believe I have about a 2-1/2" drop in the front and about a 1-1/2" drop in the back. The front is very stiff ( you can sit on it and it doesent move ) and the back is stiff but not that too stiff( I wanted it this way so I can get better traction on the streets, and get that raked look )
Old Jan 12, 2002 | 03:17 AM
ohh yea heres a pic:
:http://community.webshots.com/user/bigmike92z28
Its a terrible pic but its all I got that is recent
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
AkDrifted
Aug 17, 2015 07:45 PM
novaderrik
Aug 10, 2015 12:44 PM
anesthes
Aug 8, 2015 09:37 PM
