recommended spring compressor?
Old Oct 30, 2017 | 06:23 PM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
What spring compressor are you guys using for your third gens?
How many uses are you getting before the spring compressor dies?
Today, I killed a $35 Autocraft model AC685.
I was able to do one test-compression, and then install one spring before the threads were toast. Yes, I did use lubrication on it.
I used an impact wrench with the AC685. There seems to be some belief that one should not use a power wrench on these cheap compressors. There may be some truth to that. Although, the flimsy threads and soft metal on these tools inspire no confidence that they will last for long, no matter how much you baby them.
This is the one I killed today.
Old Oct 30, 2017 | 06:40 PM
W.E.G.'s Avatar
Engine: V6 2.8
Re: recommended spring compressor?
Spring-compressor action begins at 26:45
Old Oct 31, 2017 | 08:14 AM
Abubaca's Avatar
I rented one the one time I needed it. Life flashes before your eyes. Don't like that procedure at all. Definitely used a safety chain. ....with lowering springs you don't need one, so thankfully it was only the one time I needed it.
Old Oct 31, 2017 | 08:31 AM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
I rented the OEM inside compressor from Autozone.
http://www.autozone.com/loan-a-tools...sor/555573_0_0
It marred up the same way yours did. Still worked though.
I did not like the apparent strain it put on the compressor but I had no other choice. In the end it worked fine. As a precaution, I always handled the coil from the center, that way, if it did let go, I would theoretically be away from both ends of the rapid expansion.
I have also used strut spring compressors successfully on these cars. They seem to be much stronger and, thus safer but are more cumbersome to use.
http://www.autozone.com/loan-a-tools...sor/555557_0_0
Old Oct 31, 2017 | 08:38 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I use the OTC 7045B, for multiple vehicles and many times. It is much higher quality than the one you pictured.
Amazon Amazon
Old Oct 31, 2017 | 08:57 AM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I've never seen that design before. Interesting.
Old Oct 31, 2017 | 09:25 AM
Engine: 350 TPI L98
Transmission: WC T5
^^ That's the one I will invest in if I have to do my springs again.
Old Oct 31, 2017 | 07:28 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I prefer the AutoZone rental, but Modify it so it works better,..... A Large socket is best IMO but as you can see, a stack of wheel-lug washers works too !
https://www.thirdgen.org/forums/susp...g-install.html
Old Oct 31, 2017 | 09:20 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Use a pipe nipple as in post #5 of the following link:
https://www.thirdgen.org/forums/susp...nt-spring.html
JamesC
Old Oct 31, 2017 | 09:44 PM
W.E.G.'s Avatar
Engine: V6 2.8
Many - and majority - very high reviews on the Amazon site.
Link to OTC manufacturer's site: https://www.otctools.com/products/fr...ing-compressor
Old Oct 31, 2017 | 09:53 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
I like it because the design is such that it can't slip radially around the coils like those other potentially can. I have had them slip when I was tightening initially, real pucker factor there. It also has a ball thrust bearing in the screw, so it doesn't bind when you start getting the spring pressure up there. Also has plates for two different coil sizes. Well worth the money if you're going to use it two times or more. I have used it about 5 times so far and will use it again many times
Old Nov 3, 2017 | 04:54 AM
IROCZ1989's Avatar
Car: 1989 IrocZ
Engine: 421 Dart Stroker
Transmission: 4L60E Cahall Performance Built
Axle/Gears: Midwest Chassis Fab 9/ 3.55 gears
The otc is the one you need.
