What can I do to strengthen my body after cutting an access hole for fuel pump
Car: 1991 Chevy Camaro RS
Engine: V6 3.1L
Axle/Gears: Stock
I took the easy way out and I regret it. How much HP can it handle now?
Car: 1991 Camaro RS
Engine: Hot 355ci
Transmission: Beefed TH350
Axle/Gears: 4:10
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: What can I do to strengthen my body after cutting an access hole for fuel pump
It's more about being in an accident and fuel getting in the car
Engine: 4++,350 & 305 CIs
This. ^^^^^^
I wish GM would have put an access panel in these cars but I'm sure it wouldn't have been cheap to do with all the new crash testing needed to make sure it was safe. Since the panel would be in a crumple zone, I doubt it would fly. Esp wouldn't with some of the hack jobs I've seen on FB.
Car: 1991 Camaro RS
Engine: Hot 355ci
Axle/Gears: 4:10
Car: 92 Firebird
Engine: 4.8 LR4
My car was hacked before I bought it, and I didn't find out until later. I would always smell fuel in the car on a hot day. It is absolutely the WRONG way to change a fuel pump since you have to cut through the fuel lines and there is no way to get a proper connection on the lines after being cut.
There is a reason most OEMs do not put a fuel pump access in the car, liability.
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
No, no you can't. Unless you make a stiffening ring and another piece that can in no was separate from that piece, the stiffener would have to be fully welded all the way around and the mating piece would need to deform with the stiffener. You're only asking for problems in an accident.
Car: 92 Firebird
Engine: 4.8 LR4
I didn't even think about CO. When I did the overhaul in my car, I ran out of time to weld the hole closed again, but I "re-sealed" it as best I could, but even with the windows up and sitting at a light I can smell exhaust sometimes.
Oh wait... you're asking about the CAR body?
Yeah definitely need to seal it up against the exh gases getting into the car. I can tell you from personal experience, members of the other sex (I'm assuming you're male... therefore I speak, in general, of females) will ABSOLUTELY not even get NEAR the car, let alone INTO it, and even more remotely, will LIKE it, if it smells of exh gas. Any hole in the body will leak that into the vehicle if not properly sealed. These days, in addition to making certain the hack job is at least sealed back up, I'd be checking the welds around the wheel wells, esp on the pass side starting at the spare tire well and going forward from there.
Car: 88 Camaro
Engine: L98 350
The carpet in my 88 has a heavy plastic backing on it, can't imagine any fumes getting through that the car. That tank and fuel pump setup is about as poorly engineered as anything I've run across. Except maybe the alternator on the mid 90s Olds/Lumina with the DOHC engine with the alt. underneath the engine.
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Find one in the scrap yard, and Sawzall the rear deck panel from the donor. Fabricate a suitable patch panel from the donor metal. Use “nutserts” for a clean job.
https://www.summitracing.com/parts/aaf-all19465
Car: 86 Trans Am WS6
Engine: 383 stroker
the only way to truly make an access hole in a thirdgen work and function correctly is to drop the tank and weld the access door in which defeats the purpose of even doing it since you'll already have your tank dropped lol
I agree with the school of thought that I'd never cut my car , and since it's just like that southpark movie "bigger , longer & uncut" , it's gonna stay that way . But , what of the folks who had the decision already made for them ? Folks who bought a car that already WAS cut ? Well , the TGO member "Tibo" had that very situation and produced one of the best access hole repairs I've ever seen . Yes indeed he DID have to remove the tank to properly repair the butchery so there is no real "quickie painless no/low effort" way to do this right , but when given lemons the dude made the best lemonade I've seen and any of you with poorly hacked access holes really oughta look up his thread on how he fixed his . Now , for those whose cars aren't yet cut , since the tank 100% absolutely HAS to come out to do the pump the "factory" way , and since it also HAS to come out to do a proper access hatch , ask yourself this ; "If I'm gonna have to take the tank out anyway , why not just buy a good (read = expensive compared to buying by the lowest possible price) pump and do it the right way , since a good pump will likely last longer than most of the rest of the car , and save all the fabrication time of properly installing a hatch ?"
In all reality , with a good pump , how may times ARE ya gonna be changing it , once in the car's lifetime ?
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
And thanks for the kind words OrangeBird!
SneezeCheese
Jan 11, 2015 03:34 PM
