No Power Steering at Low Speed Turn
Car: 88 Iroc
Engine: 5.7 tpi
Hi all,
I replaced my power steering pump 2 weeks ago due to a leak from the reservoir seal. Was working fine until a few days ago now i'm getting a random loss of power steering at low speed turns. My belt is maybe three months old and seems to be tight so i don't think its slipping. The fluid level is good and there are no air bubbles present. I do have a belt chirp in the mornings maybe due to the pulley not being lined up but that shouldn't cause it. Any ideas?
88 Iroc Z
Serp Belt.
88 Iroc Z
Serp Belt.
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: No Power Steering at Low Speed Turn
Sounds like the pump may be sucking air, or just failing altogether. Just because you replaced the pump doesn't mean it is good unfortunately
Car: 88 Iroc
Engine: 5.7 tpi
Where would it be sucking air from? Bad cap? Yeah I'm thinking of replacing it again but wanted to do tests first.
Thanks.
Thanks.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
It would sucks air through a leaky hose or connection. cap doesn't matter.
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Inspect your belt for fluid. Clean it with brakecleen.
Sounds like there's air trapped in the system.
Make sure there is enough fluid in it, too much is better than too little (I've seen a few cars that just didn't work right unless it was way overfilled according to the marks, the worst that will happen if it's overfilled is the fluid will come out the cap when it gets hot, hose it down and don't worry about it). Jack the car up with the front tires not touching the ground, start the engine and turn the steering wheel back and forth the whole way a bunch of times. That will pump the fluid through the whole system and should pump any air bubbles out. Check the fluid level, top off if necessary and repeat till the fluid level doesn't change and you don't see any bubbles in the fluid.
Back down and take it for a ride.
Car: 88 Iroc
Engine: 5.7 tpi
Thanks. I did the off ground air bleed process on Monday night and it did help get some air out but not all. I found that my pressure hose has a small leak so my new one will be here tomorrow. Then I will do it again.
MaxxMitchell
Exterior Parts for Sale
Jan 15, 2010 07:34 AM
Firebat
Jan 27, 2006 11:38 PM
