Eibach prokit / Hotchkis
Old Apr 5, 2018 | 02:55 PM
Junglebill's Avatar
Car: Camaro
Engine: 350 Tpi
Thinking about lowering my camaro . Which springs will give the most drop when settled , the eibach prokit or hotchkis springs? Both claim 1" front and rear .
Old Apr 5, 2018 | 02:57 PM
Drew's Avatar
Re: Eibach prokit / Hotchkis
If I remember correctly, they're the same springs.
Old Apr 8, 2018 | 12:41 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Eibach Pro Kit: 714 lb/in linear front 1 inch lower front
109/177 lb/in progressive rear 1 inch lower rear
Eibach Sportline: 700 lb/in linear front 1.6 inch lower front
80/137 lb/in progressive rear 1.3 inch lower rear
The Hotchkis I "believe" are 600 lb/in on the fronts. For the added cost over the Eibach with no performance gain, I would recommend the Pro-Kit.
I don't recommend the Sportlines to anybody. They're for looks only. Ride quality is going to be bad. The fronts are OK. But the rear end uses the bump stops on purpose. No performance benefit over the Pro-Kit.
Something to remember though, the advertised 1" drop may very well be less than that. When I replaced my original sagging springs with new stock height springs, the driver sides went up by 1.7" (front) and 1.5" (rear). Passenger side less so (0.25"). So in my case, putting some Pro-Kit springs on would have made the driver side higher than my original springs were.
GoldenSwordZ28
Apr 29, 2002 06:07 PM
ThirdGenZ28 92
Apr 29, 2002 04:06 PM
BG87z
Apr 29, 2002 10:17 AM
Makaveli
Aftermarket Product Review
Apr 25, 2002 09:47 AM
89 GTA Dave
Oct 22, 2001 11:42 AM
