Suspension advice
Old Apr 6, 2018 | 01:53 PM
steves's Avatar
Car: 1991 Camaro RS B4C
Engine: 5.7 TPI Crate Motor
Transmission: WC T5
Axle/Gears: 10 Bolt 3.42
Suspension advice
Right now I am having an aluminum headed 350 installed into my car. With the old motor in my car the front sat higher than the rear so I am expecting it to be worse when I get it back. I need some suggestions for springs and struts to even out the stance and restore the factory handling. I know the Konis are the best but don't want to spend that kind of money. I am looking for best bang for the buck.
Old Apr 6, 2018 | 04:05 PM
Re: Suspension advice
Start with a set of new rear springs. Moog CC635 or 5665 (variable- or constant-rate, respectively); CC635 is most like stock. As far as shocks, people seem to like the KYBs for a cheap alternative but I have never tried them myself so I only repeat what I've seen about them.
Do those first, then come back and tell us if you think the front needs work too. (probably will...)
scorchmaster
Sep 23, 2007 10:45 AM
91greenbird
Mar 26, 2006 06:46 PM
Meatwad
Apr 2, 2005 10:35 PM
Calderone
Dec 10, 2001 09:37 AM
