Lower Control Arm
Old Jan 5, 2002 | 03:57 PM
PimpCamaroRS's Avatar
Lower Control Arm
My wheel hop is getting way to bad so whre can i find some Lake Wood LCA's or another good band for CHEAP! thanx a lot
Old Jan 5, 2002 | 04:06 PM
lca
alsowhat are LCA relocation brackets and are they worth gettig with the LCA's
Old Jan 5, 2002 | 09:54 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
Re: Lower Control Arm
www.summitracing.com lak-20140 $83.95. they are called trailing arms not lower control arms. those are the things up front that the spring rides in. also sometimes called a-arm. just a little peeve of mine. the relocation kit i think spohn has. it moves the trailing arm down in the front where it bolts to the body for improved angle. i have the trailing arms and adjustable panhard rod lak-20440 $87.95. but not the relocation brackets. definate improvement.
Old Jan 6, 2002 | 01:28 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
The relocation brackets will help you wheel hop MORE than LCA's will, especialy if your car is lowered, the work by makeing the REAR mounting mount on the rear axle for the LCA giving you a better angle for the LCA.
Old Jan 6, 2002 | 10:12 AM
so what i should get is REAR LCA's with a relocation bracket and my wheel hop should be pretty much gone right?
Old Jan 6, 2002 | 09:45 PM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
LCA relocation brackets are all you should need to eliminate your wheel hop. New LCAs won't hurt but aren't necissary.
deracer
Apr 11, 2016 12:04 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Dialed_In
Aug 20, 2015 01:45 PM
