Indexing springs
Old May 10, 2018 | 06:57 AM
Junglebill's Avatar
Car: Camaro
Engine: 350 Tpi
Indexing springs
Curious. What' the point of placing the tail end of the spring in between the 2 drain holes ? When their is a grove just past the 2nd drain hole that stops the spring from going any further . Is it to give room for the spring to settle?
Old May 10, 2018 | 11:51 AM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
Re: Indexing springs
I always butt the spring end up against the stop.
Old May 10, 2018 | 09:10 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
The holes allow water to drain from the arm and not rot the spring and arm out.
Old May 11, 2018 | 08:26 PM
83 Crossfire TA's Avatar
The ends of the spring are not flat, they will not sit flat in the pocket and the arm sits at an angle to the spring, so depending on where the end of the spring is the car will sit at a different height. The indexing holes give you a way to line the springs up within about an inch, ensuring even heights and loads side to side.
It has nothing to do with draining water.
Old May 12, 2018 | 11:06 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
If I'm wrong I apologize, it's something I read years ago as an extra function of the holes.
Old May 13, 2018 | 07:59 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Regarding the inspection drain holes. From my 85 shop manual:
After assembly, end of spring coil must cover all or part of one inspection drain hole, the other hole must be partly exposed or completely uncovered.
JamesC
Old May 13, 2018 | 08:05 AM
Junglebill's Avatar
Car: Camaro
Engine: 350 Tpi
Originally Posted by JamesC
Regarding the two holes. From my 85 shop manual:
JamesC
Thank you . Just finished my spring install and the tail end sits just before the 2nd hole
ThridGen_RS
Aug 19, 2016 12:28 PM
Gecz28
Jul 15, 2015 01:48 AM
dust3r
Oct 17, 2010 08:59 PM
Wishmaster's87IROC
Jan 14, 2007 10:14 AM
Wishmaster's87IROC
Mar 6, 2003 09:24 PM
