SPOHN poly/spher. combo ??
Old Jan 5, 2002 | 11:39 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
Are the poly/spher. combo LCA just as adjustable as the dual poly. ones
I was looking at the pics and they adjust differantly
also do the poly sides have a grease fitting ?
same with the PHB too ..grease I mean
Thanks for ant info
Old Jan 6, 2002 | 12:14 AM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
Yes, the poly/spherical LCA's adjust differently but just as well. Yes, they have a grease fitting on the poly side, as does the panhard bar.
Old Jan 6, 2002 | 07:28 AM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
.. and the poly/spher is the way to go for road racing.
Old Jan 8, 2002 | 06:22 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
wouldn't having both ends sperical rod ends be the better way to go?
Old Jan 9, 2002 | 08:47 AM
blak92!'s Avatar
Spherical bearings are the way to go, but the noise is unbearable to drive with. I have the herb adams LCA, but only use them when I go to the track. I use the stock arms with poly bushings for everyday driving.
Old Jan 9, 2002 | 01:02 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
would adding sound deadening material to the inside such as Dynomat make haveing spherical rod ended LCA and panhard bars bearable??
Old Jan 9, 2002 | 04:02 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
There's also the wear factor. Rod ends don't last as long as bushings do. For a daily driven street car the ploy/rod end combo is a better way to go.
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
darwinprice
17
Oct 11, 2015 11:51 PM
Nervous2
Oct 8, 2015 10:53 PM
matt's 91rs/tt
LSX and LTX Parts
Oct 8, 2015 06:11 AM
