is the 1LE brake system really that much better...
Old Jan 6, 2002 | 11:20 PM
breathment's Avatar
IS the setup really that much better then say going out and getting bigger rotors\calipers, and just upgrading the whole system with like Baer Brakes or something??
what about price\availability?
Old Jan 6, 2002 | 11:53 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Well, installing the the 1LE setup means going out and getting bigger rotors and calipers already. Some of the Baer setups use the same 2 piston PBR calipers with similar or slightly larger rotors, so I imagine performance would be comparable at least.
If you modify your own spindles, the 1LE setup is considerably less expensive than an aftermarket kit. All of the parts are readily available except for one of the caliper carrier brackets which will soon be available from Steve Spohn.
Old Jan 7, 2002 | 05:06 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Apeiron is exactly right. Not to mention the fact that it is a whole lot cheaper.
Thanx,ANDYZ28
Old Jan 7, 2002 | 10:01 PM
breathment's Avatar
y isn't the 1LE tech article working?????
Old Jan 7, 2002 | 10:23 PM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
... I believe that the 'anchor' brackets are dryin up now, too. Couldn't find a left side anywhere.
Old Jan 7, 2002 | 11:21 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I think you're talking about the same part we are.
Old Jan 8, 2002 | 11:51 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
I've noticed that 1LE replacement pads are like triple the price of standard pads why is that. I know they are bigger but come on, triple the price? I've seen the standards for around 40 bucks compared to the 1LE that run up to 160 bucks
Old Jan 8, 2002 | 04:09 PM
breathment's Avatar
WHEN????
Old Jan 8, 2002 | 09:11 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Sometime in May 2002!!!!!!!
Old Jan 9, 2002 | 01:13 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Why do pads for 1LE brakes cost so much more over standard pads
Old Jan 9, 2002 | 01:43 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I don't know, my 1LE pads were less than $10 more than the regular pads.
Old Jan 9, 2002 | 04:42 PM
breathment's Avatar
from what i have heard and seen, its the calipers that will set u back the most.
Vintageracer
Jan 10, 2020 05:33 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
gta90
Sep 15, 2015 04:00 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
zayne0
Aug 24, 2015 07:22 PM
