Helper springs, air shocks or OE springs for low bird that also pulls a trailer
Old May 27, 2018 | 12:29 PM
oil pan 4's Avatar
Car: 89 Firebird
I put in lowering springs on my firebird, so I still have the old springs (this was only incase I needed to put themback on for some reason).
Problem is 2 or 3 years later I think the lowering springs have finally settled in and it's a little too low for the rough streets and speed bumps around town.
I have no problem plumbing in a compressor. I have a spare ARB compressor left over from putting the air locker on my suburban, I already had a big Gast air compressor on it. So not worried about getting, installing, wiring or plumbing in a little conpressor.
Right now I am only worried about lifting the back a little.
Plus for the front the only option I see available, affordable and practical are air helper springs.
For the rear I see I can get helper springs and air shocks for about the same price.
But which one to get?
I hear the helper springs don't have a real long life expectancy are air shocks any better?
Which one do you think would "pump up" faster between air bags vs air shocks?
There is one big speed bump that I particularly hate, I don't want to sit there for 5 minutes while the suspension pumps up so if one is faster than the other that would be good to know.
I would like to be able to pump up the air suspension as I go into town to avoid scraping and not feel like I am driving a forklift as much.
I'm assuming air shocks take less air volume at higher pressure and helper air bags take lower pressure but at a much greater volume, would this assumption be correct?
Or do both systems run around the same pressure?
I also pull my 4x8 utility trailer so adjustable rear hight would be ideal.
Riles
Feb 19, 2007 04:21 PM
87tpi
Northern California
20
Nov 8, 2006 12:36 AM
84406
Apr 27, 2006 10:05 PM
irocbirdbuilder
Nov 22, 2005 08:01 PM
jmon92conv
Aftermarket Product Review
Nov 30, 2001 12:11 PM
