Broken frame from gearbox (not just a crack)
Old Jul 8, 2018 | 08:05 PM
bchapp's Avatar
I recently purchased an auto 92 RS w/305. The seller disclosed a leak in the power steering that I did look over. This weekend I was investigating more and noticed the gearbox moved when turning the wheel. After degunking the area I can now see what looks like the gearbox has broken into the frame. There is also a break and deformation in the pinch welds. Can someone confirm that this is what I am seeing? What does this mean for the car and how can it be fixed?
Edit: all my pictures appear to have come out upside down...
Attached Thumbnails Broken frame from gearbox (not just a crack)-img_1476.jpg   Broken frame from gearbox (not just a crack)-img_1475.jpg   Broken frame from gearbox (not just a crack)-img_1474.jpg   Broken frame from gearbox (not just a crack)-img_1472.jpg   Broken frame from gearbox (not just a crack)-img_1469.jpg
Old Jul 8, 2018 | 11:40 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Broken frame from gearbox (not just a crack)
Yeah that's all messed up. You need to remove the box and rebuild the area on the frame that's damaged. That means either fabricating a new plate to weld into the frame section or grafting a section in from a doner car.
It's a "common" enough problem.
Fwiw, I'm cutting up a car at the moment, I could cut a check of that part if the frame off if interested.
Old Sep 12, 2018 | 09:37 AM
Strick1's Avatar
Car: 92 Vette, 83 Camaro
Engine: 305 going to 95 LT1
Transmission: 5 speed going to T56 6 speed
Axle/Gears: 3.73 posi with disc brakes
Its usually caused by hitting a curb side ways hard or while turning and hitting that curb. After the fix, make sure you get a bar that ties both sides together.
Old Sep 13, 2018 | 04:21 PM
Hawgtied's Avatar
Car: 1988 IROC "The Duece"
Engine: 5.7 TPI L98
^^^^Is that what the wonder bar does?^^^
Old Sep 13, 2018 | 04:25 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
That's why the Wonderbar was invented...
rkg8554
Dec 31, 2023 06:43 PM
ron83TA
Aug 25, 2006 12:56 AM
CRZYTRN-92Z28
Nov 6, 2005 11:09 PM
Soulrev
Jun 23, 2003 05:13 PM
GOLD85
May 11, 2001 11:20 AM
