Id like to pick up a wonder bar and after a search, many people are using TDS. Does anyone have any reason not to go with TDS?
scooter
close
- Join DateSep 1999
- LocationNJ
- iTrader Positive Feedback100
- iTrader Feedback Score(11)
- Car92 Firebird
- Engine4.8 LR4
- TransmissionT56
- Axle/Gears3.45 9 Bolt
- Liked:308 Times in 243 Posts
It's just like the GM one, but better since he added provision for a 3rd bolt in it. That's what I am planning on buying
I have a TDS one on both my '86 and '92. I don't recall any issues installing either.
GeneralDisorder
close
I did enough research on the options to find the best one and yes the TDS was it. No complaints except the sticker didn't last long. LoL
battmann
close
i went with the UMI wonder bar and also purchased their sway bar relocation brackets. the brackets allow you to install straight sway bar mounts - replacing the stock offset mounts. i have all UMI suspension parts on my car so that was the main reason for going with them. all of their products are quality pieces and they have sales throughout the year (usually around holidays).
here's the links:
2030 wonder bar
2119 front sway bar relocation brackets
here's the links:
2030 wonder bar
RedLeader289
close
- Join DateOct 2013
- LocationLouisville, KY
- iTrader Feedback Score(3)
- Car1983 Z28
- Engine385 Fastburn
- TransmissionT-5
- Axle/GearsBorgWarner 9-bolt posi, 3.27 gears
- Liked:159 Times in 130 Posts
I got one of their refurb factory units, works fine for me.
I just installed my TDS WB on Sunday. Looks good and works well...
T.L.
close
- Join DateSep 1999
- LocationColorado USA
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car'83 Firebird (T/A Clone)
- Engine350 with L-69 components
- Transmission700R-4, 2000 RPM stall converter
- Axle/Gears10-bolt/3.73 ..
- Liked:825 Times in 633 Posts
How is it better than the Global West bar?...
scooter
close
- Join DateSep 1999
- LocationNJ
- Car92 Firebird
- Engine4.8 LR4
- TransmissionT56
Quote:
Who said that? It's essentially the same as the rest, with two mounting holes. The TDS one is easier to installOriginally Posted by T.L.
How is it better than the Global West bar?... vinny R
close
- Join DateMay 2015
- LocationFlorida
- Car1991 Z28
- Engine305 TPI
- Transmission700R4
- Axle/Gears3:42 Auburn
- Liked:286 Times in 217 Posts
Quote:
The advantage with the TDS is a 3rd mounting hole. You pull out one of the steering box bolts and it goes through the mounting plate so it directly ties in the steering box to the bar. All the others just use the 2 sway bar mounting bolts.Originally Posted by scooter
Who said that? It's essentially the same as the rest, with two mounting holes. The TDS one is easier to install I got the TDS because I heard some other brands had trouble clearing the dual fan setup.
The TDS fit perfectly.
+1 for the TDS bar. I have one, love it. Super easy to install, everything lines up mint.
Cool, thanks. I saw klowny on youtube install the detroit one, but its like $400. So TDS seems way more budget.
