firebird sits uneven in the rear HELP
Old Oct 28, 2018 | 02:45 AM
luca's Avatar
Car: Firebird
Engine: 3.1
Transmission: 700r4 /borg warner t5
Well i know there are some threads about that some thirdgens are lower or higher at one side but i didn't find a solution yet
my firebird is in the rear right about an inch too high ,however at the front they are the same
i pull out the springs in the front and the back (they have the correct length and are not broken ) replaces the A arm bushings, balljoints ,struts and shocks but still sits uneven
the correct spring isolators are still in place and the springs are installed correctly
i dont think that my car is twisted like some in the forum say at other cars that have this
can this cause a bad sway or track bar ?
i´m glad for any help
the left site seems to be alright
right side only in the rear is way to high
Old Oct 28, 2018 | 02:56 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: firebird sits uneven in the rear HELP
Swap the rear springs and see if the problem changes sides. This might tell you if one the spring has a different compressed height than the other. Springs don't lose spring rate but they do take a set and change compressed height over time.
Old Oct 28, 2018 | 03:01 AM
luca's Avatar
Car: Firebird
Engine: 3.1
thanks but i tried this but why should sit one side higher if the other one is correct
MilehighBird
Jan 22, 2006 11:01 PM
rjright
Jul 21, 2005 10:33 PM
rocc4u
Oct 8, 2002 05:59 AM
ChevyGuy87
Apr 30, 2002 11:21 PM
snoozeyaloose85
Apr 30, 2001 08:58 PM
