Front tire rub to sway bar
Car: 1991 Pontiac Firebird Trans Am
Engine: 5.7L TPI
Transmission: 4 speed 4L60/700R4
I have a 1991 T/A. Has stock rims with stock 245/50/16's. Offset 0's in front and 16's in the back. Front end components are either new or have been checked to be fine by two shops. Has been aligned and is within spec. Only apparent non-OEM front end are the lower control arms (tubular instead of the OEM stamped). Car does not appear to have been in any collisions. Problem is that when turning and getting to about 90% full turn, the tires rub on the sway bar.....hard. Any ideas? I'm sort of at a loss on this one.
Engine: 4++,350 & 305 CIs
Re: Front tire rub to sway bar
Are the stops on the control arms correctly hitting the spindles ?
Car: 90 Formula / T-tops
Transmission: MD8
I thought the WS6 setup rubbed up front on full hard turn. Havevn't done one in a long time, don't recall exactly what the circumstances are to create it and if it was on one side only or both.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Sounds pretty simple. The tubular arms are either built wrong, or lack steering stops which the factory arms had. The wheels are turning more than they should and are hitting the bar. If the tubular arms have stops, they need to be lengthened.
That is a factory option... err.. factory design flaw. My car rubbed on the fender wells since new. There was a service bulletin on it.
However, I'd have to look at the sway bar for rub marks. I believe there are.
Car: 1992 Z28 Targa Top. Full air ride
Engine: 305 5.0 tpi v8
Transmission: A4
Axle/Gears: 3.73 gears posi
My car does the same thing but I know the issue. Sure doesn't hurt anything but it's annoying as hell.
Beater79TA
Aftermarket Product Review
Feb 26, 2019 08:41 AM
Steven6282
Mar 23, 2012 02:19 AM
89FormulaRoth
Nov 21, 2001 04:13 PM
