Has anyone installed Spohn tubeular a arms? How do you get the coils in?
Old Dec 22, 2018 | 07:42 PM
Clampmaker's Avatar
Car: 91 rs
Engine: 383 stroker
Transmission: Tremec tko600
How dou you get the coils in? I have no engine or trans in car. Just the shell. Rebuilding car from ground up & need to know it there is a trick to getting suspension installed with out the driveline weight to help. Any advice would be appreciated
Old Dec 22, 2018 | 08:22 PM
PaulyC's Avatar
Re: Has anyone installed Spohn tubeular a arms? How do you get the coils in?
They are a pain due to the depth of the spring pocket but if you use a spring compressor like the one below you can get them in. The hook style can't get them compressed enough while still being able to install the spring and removing the compressor. Somebody may chime in with a different experience. My opinion is this compressor is definitely easier to use but it is a lot more expensive.
Once you get the spring into position, just use a floor jack under the a arm to compress the spring and connect the strut.
Amazon Amazon
Old Dec 25, 2018 | 10:48 AM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
I got them in with the hook type compressor, but it was a pain in the a$$, I wish I knew that other type existed, I'm lucky I still have all my fingers with the number of times they slipped out of the compressor
Old Dec 25, 2018 | 11:47 AM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
I had such a hard time i ended up replacing them with a different set. I have 2 pairs of spohn a arms and they are both different designs. one pair the springs went in in just minutes but the other was a no go.
Old Dec 31, 2018 | 05:00 AM
Charliek's Avatar
Car: 86 Z28
Engine: 283
Axle/Gears: stock
When using the hook style with our cars you need to add a small piece of steel pipe to the nut side of the compressor. This will allow you to put the top hooks higher on the spring and inside the top pocket, which also allows you to put the lower hooks just above the control arm pocket.
tonythetoad
Nov 1, 2010 07:07 PM
krisb410
Exterior Parts for Sale
Aug 4, 2007 03:57 PM
Gta-Paladin
Feb 2, 2002 01:30 AM
R.O.B.
Aug 5, 2001 01:29 PM
