trouble getting brake drum off
Old Jan 9, 2002 | 03:57 PM
Illegal T/A's Avatar
I am having trouble getting my drum off i have tried pounding around the sides, and it seems stuck. any other methods.
Thanx alot
Old Jan 9, 2002 | 04:10 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Can you get an adjuster wrench in there to loosen up the tension on the brake shoes? That may help. Also, a little 3-in-1 or WD-40 sprayed around the lugs nuts and center hub might help it come loose.
Old Jan 9, 2002 | 06:05 PM
How would I get a wrench in there if I cant get the drum off? Would the bolt in back of the wheel cylinder loosen it up?
Thanx
Old Jan 9, 2002 | 06:34 PM
82camaro's Avatar
Car: 82 camaro SC
Usually they have an access panel on the back just big enough to to stick a screwdriver in and adjust the shoes a bit. If the drum doesn't move at all, it is probably rusted on. Try a little PB blaster.
dbrochard
Oct 3, 2015 12:43 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
rudolphschenker
Sep 4, 2015 02:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
