Umi caster camber plate shaft bushing?
Old May 30, 2019 | 06:16 PM
Dexint88's Avatar
Just got my umi caster camber plates today went to install them and there is a bushing insert that goes into the spherical bearing . The directions don’t say whether it is inserted from the top down or from the underside of the bearing ? Any help is appreciated
Old May 30, 2019 | 10:14 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Umi caster camber plate shaft bushing?
Is it a bushing or just a spacer? Spacers usually go on top (under the nut).Some set-ups need a bushing due to the strut being too small dia for the bearing.If thats your case i would guess the bushing goes in from the bottom.Pics help.
Old May 31, 2019 | 07:49 AM
Dexint88's Avatar
There at my garage looks like this though
Old May 31, 2019 | 09:18 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Definitely bushings, different sizes too.I'm guessing depending on the strut dia.Which one you use will depend on the strut.Some don't even need the bushing, but those certainly look like they'd go on from the bottom.
Old May 31, 2019 | 10:11 AM
Dexint88's Avatar
Well those aren’t the actual part I just googled it I’m working now lol , but there’s only one and it’s just like that piece
Old May 31, 2019 | 10:30 AM
Fullmonte77's Avatar
Car: 85 Berlinetta
Axle/Gears: 10 bolt 3.42 with Torsen posi
Call UMI. Their guys are always happy to help with any issues or problems.
6SIX6
LSX and LTX Parts
Jul 8, 2014 01:58 PM
tonys91rs
Jun 25, 2012 09:19 AM
Chicago89RS
Dec 4, 2010 10:35 AM
Josh R
Mar 1, 2009 12:42 PM
Mathius
Jun 8, 2003 01:35 PM
