UMI Spherical Caster/Camber Plates!!
Old Feb 7, 2010 | 01:32 AM
Chicago89RS's Avatar
Car: 1989 RS Camaro
Engine: 305 TBI
Transmission: 700-R4 with Overdrive
Haha, it's amazing what you can find online when you can't sleep. UMI is now offering a spherical caster/camber plate for only $217.99!!! Check the link below.
http://www.umiperformance.com/catalo...hgl0viul2sdcr0
Old Feb 7, 2010 | 01:56 AM
twigger's Avatar
Car: '91-Z28/'03 Honda 919
Axle/Gears: '99 Zexel 3.42
Re: UMI Spherical Caster/Camber Plates!!
Wow those have a striking resemblance to another product out there?!? Too bad those dont have a lifetime warrenty or I would buy them.
Old Feb 7, 2010 | 01:59 AM
Twin_Turbo's Avatar
They look like an exact copy of the J&M Hotpart ones.
Old Feb 7, 2010 | 12:12 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
only difference i see is the hotpart ones have stainless bolts for the adjustable bearing, and the mounting plate on the hotpart ones are 5/16, a hair heavier. Along with the lifetime warranty.
Old Feb 8, 2010 | 05:59 PM
UMI Performance's Avatar
Hello Everyone,
Yes we are now offering the caster and camber plates.
We can offer you a lifetime warranty on the bearing as well. The bearing inside is a USA made spherical bearing with a self lubricating Teflon lining. If you wear it out we will replace it
We did build ours from 1/4" thick, I feel 5/16" is just unnecessary weight. We do offer thicker retainers on the bottom, others use 1/8" thick with low grade hardware and we use 3/16" thick with 10.9 hardware. We actually snapped a competitors hardware awhile back installing a set for a customer. Also our tubing is DOM and others use ERW.
If anyone has any questions please ask. Thank you!
Ryan
Old Feb 8, 2010 | 06:31 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
snapped a bolt during an install? wow! how tight did it get tq'd??
J&Ms have a lifetime warrenty on the whole part, not just the bearing.
Old Feb 8, 2010 | 08:04 PM
The nut was just starting to apply pressure when it snapped on us.
Out of curiosity why does J&M offer a lifetime warranty on this item only and no other item? We offer a 2 year warranty on all our products and have always cured an issue if one has came up. We can offer a limited lifetime warranty as well... as you can see we do not have any worries regarding our product.
Thank you,
Ryan
Old Feb 9, 2010 | 03:40 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Thank you,
Ryan
Must have been defective? You should be able to torque even grade 0 hardware to specs.
Old Feb 9, 2010 | 08:26 AM
89_RS's Avatar
Car: 2003 F-150
Engine: 4.6L Modular V8
Transmission: 4R70W
Axle/Gears: Ford 8.8"/3.55 LSD
These guys are going on the buy list. You get the mount AND new retainers. Spohn was the only other company to make retainers and they wanted $40 for them in addition to the mounts. Definitely a deal sealer for me. They cost the same as the J&M part and come with the retainers. All around, I think that this is my spring break fun time right here.
Old Feb 9, 2010 | 10:02 AM
hotpart's Avatar
Thank you,
Ryan
Please don't be misleading on your competition. All of our parts come with a lifetime warranty including all of our poly bushings. The only thing that does not have a lifetime warranty is the spherical rod ends on our race panhard rods and race lower control arms.
Our mounts do and always have come with the lower bolt retainers. The cost is also not the same with the UMI parts coming in about $60+ more expensive.
Old Feb 9, 2010 | 10:53 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Hello Everyone,
Ryan
Hey Ryan,
How tall are these?
Old Feb 9, 2010 | 12:27 PM
UMI Sales's Avatar
Originally Posted by The Project
Hey Ryan,
How tall are these?
They are 3.25 tall. The inside travel is 2 inches. If you have any other questions feel to ask!
Brad
Old Feb 9, 2010 | 12:33 PM
Sounds great! There will be a sale coming up...so watch for it
I apologize...I was unaware of this, I only saw a warranty listed on this product.
They were the same price two days until the price got cut by $60
Hey Ryan,
How tall are these?
These are just over 2" tall.
Hope that helps!
Ryan
Old Feb 9, 2010 | 12:39 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Axle/Gears: open rear, 3.42 gears
Originally Posted by UMI Sales
They are 3.25 tall. If you have any other questions feel to ask!
Brad
Hope that helps!
Ryan
did i miss something?
Old Feb 9, 2010 | 12:45 PM
89_RS's Avatar
Car: 2003 F-150
Transmission: 4R70W
That I did not know. I couldn't exactly find it on your site. Thanks for the info!
Old Feb 9, 2010 | 12:54 PM
Brad measured the total height with the bearing installed, I was supplying the inside travel. The post is corrected to reflect this.
Old Feb 9, 2010 | 01:27 PM
Car: 89 IROC
WOW....UMI introduces a new part and J & M suddenly drops thier pricing by almost 30%. Someone's worried....
Old Feb 9, 2010 | 02:31 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
UMI where is your 82-92 K-Member!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Part looks AMAZING as always...
Old Feb 9, 2010 | 02:49 PM
Stephen's Avatar
Car: 87 GTA
Brad
Is that stock height, or increased height for a lowered car?
Old Feb 9, 2010 | 03:20 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
increased by about an inch
Old Feb 9, 2010 | 06:15 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
yeah, where is that elusive item?
Old Feb 9, 2010 | 07:33 PM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
More competition = buyers win.
I've always thought these things were too expensive (I'm cheap).
$152.25 sounds perfect!
Old Feb 9, 2010 | 09:38 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
Exactly, we can only hope hotpart starts ripping off UMI's K-members so I can afford one.
...At least it wasn't the Chinese companies...yet.
Old Feb 10, 2010 | 08:06 AM
UMI Sales's Avatar
Thanks for the good comments....The K Member will be available shortly. But at this time I am unable to give a exact time it will be available to the public.
Thanks Again
Brad
Old Feb 10, 2010 | 09:05 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Thanks Again
Brad
hmmm, seem to remember hearing this a couple years ago
Old Feb 10, 2010 | 10:25 AM
89ROC-Z's Avatar
Car: 89 IROC-Z
Thanks Again
Brad
Tell us a date now!!!!! lol i really cant' wait for it...if it fits like your other products it'll be top of the line
Old Nov 17, 2010 | 04:16 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Axle/Gears: Strange S60 3.73
Any updates on the UMI K-Member?
Old Nov 17, 2010 | 04:38 PM
Twin_Turbo's Avatar
This isn't the 1st time I've seen UMI sales p!ssing on competitors hardware. Not cool, especially if you consider that most their items are simply copies of what others have some up with. I'm going to get a set of these for my TA since they works wonders on my camaro. I'm going to get yours again J&M, i have them on the camaro too.
Old Nov 17, 2010 | 08:37 PM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
Man I am old I rmember when J&M was just some guy posting on here that had come up with thes new strut mounts. I was in college and broke and wanted some real bad and he was doing his first group buy. I almost started giving blood :-) just to get a pair. No shot to UMI, but J&M is Thirdgen.org born, something to think about.
I may of mispoke, It was 8 years ago. Is J&M the same as Hunter motorsports?
https://www.thirdgen.org/forums/susp...ick-strut.html
Old Nov 18, 2010 | 04:46 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
they look good to me..definitely on my to buy list
Old Nov 25, 2010 | 10:39 AM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
$185 for Black Friday. Tempting. Very tempting.
Old Nov 25, 2010 | 10:18 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Ditto to the above. + Free shipping from byunspeed.com
Old Nov 25, 2010 | 10:49 PM
Guest
Guest
Posts: n/a
J&M is NOT Hunter Motorsports. However, J&M is not a copy cat of Hunter either. THey came up with their own innovative design separating the camber from the caster settings. The innovator of all of this is Ground Control with an insert peice that just modified the factory strut into a soild bearing strut. Then Hunter Motorsports made a design (Which I owned) that was innovative but proved to be not sufficiant in durability since the units were aluminum. THey looked great, but in my case with a very modified hard cornering car the loads applied nto the bearing pressed it against the steel retainer clip and weakened the aluminum base groove causing a severe knock and unwanted slop in the bearing retention. Spohn then came out with a stee version since Hunter was not really a company in business to maufacturer these things- Hunter was a racer that had fabrication skills and built some forhimself and asked everyone else if anyone wanted to get into a group purchase then he would just built 20 sets. I jumped all over that about close to 10 years ago.
Hotparts then come out with their original design which ran into clearance issues so they started shimming the plates off the towers with spacers, eventually came this better design which was now copied by Umi. Racecraft incorporated the same basic pricipals but at least had the decency to try and make it look unique (which I commend since there is not alot you can change in function whiile still creating your own entire look- Racecraft did such honorably in my book.)
And thats pretty much the history of the strut mounts you see in existance today- Think I am going to give my ideas? Hell no. I have two top ssecret designes with very different functions from shat you have seen from anybody. Not hard to be innovative when you posses the skills and knowledge of suspensions rather than simply being a blind copycat not understanding vehicle dynamics but just making parts simply because you have metal skills and no knowledge on how they mostly function until you get schooled by hard knocks. Its American, anyone can do what they want, but I certainly try to live my life giving credit where credit is do- If I went after the buck, I would buy chinesse like this country has pretty much sold out to and cause our great current depression. Where has quality and intergrity gone? A few still have it and they get my money.
Old Nov 27, 2010 | 02:21 PM
GTA1990's Avatar
Car: 1991 Trans Am
Engine: L31, LT4 hot cam
Axle/Gears: 3:42 LSD
so tempting I put an order in - willing to take the circa $70 shipping charge (jolly ole England) and associated customs charges for these bad boys...
Old Nov 27, 2010 | 04:45 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Yes...very tempting....I just ordered a set..couldn't pass up the deal!
Old Nov 28, 2010 | 01:56 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Sorry this may be a dumb question, but what is the advantage using these vice stock replacements? Don't either one hold the strut stable?
Also, are these built for lowered cars or can they also be used with stock height suspension?
Old Nov 28, 2010 | 02:10 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
stock mounts have a rubber bushing/bearing that deflects under load. The aftermarket ones, Spohn, J+M, UMI, Racecraft, ect, all use a spherical bearing so there is no deflection. Plus they offer more adjustability of camber/caster
Old Nov 28, 2010 | 03:51 PM
Confuzed1's Avatar
Car: 83Z28 HO
Ahhh OK - So I can understand where the lack of deflection would be a plus in Autocrossing or something like that. Seems like they're for lowered cars for better handling then.
Would the camber/caster settings be altered from stock settings for that type of driving?
Old Nov 28, 2010 | 04:16 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
auto x? yes they would be much different
Old Nov 28, 2010 | 09:05 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
I jumped on the deal...
Old Nov 28, 2010 | 10:30 PM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
interested, i have been waiting for the new years discount of 20% i'm hoping they have once more just like last year. i was able to save quite a bit last year since i bought in bulk.
i just hope they will have the new years 20% off and i don't miss out
Old Nov 30, 2010 | 12:28 AM
  #42
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
which are the ones that are taller for lowered cars? my car is dropped 1.75" and i need the plates that are tall.. i remember seeing someone had them on the car and had a picture posted but now i cant find it (for reference), anyone know what ones those are? i think they were like 2" or 1.5" taller and were black in color.
Old Nov 30, 2010 | 11:54 PM
  #43
godreject's Avatar
if i remember correctly both umi and j&m's have a 1" more travel for the strut which is exactly why i want a set since my car is lower 2" or so, plus they are probably wore. plus the extra thickness in the mounts should help me clear my slp runners when using a umi strut bar.
Old Dec 1, 2010 | 03:40 AM
  #44
Guest
Guest
Posts: n/a
Spohn's are an exact steel replica of hunter's tall version aluminum units. THey have two inches additional clearence
Old Dec 4, 2010 | 10:35 AM
  #45
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
thanks Dean, thats the ones i was talking about.
David
LT1Formula
Oct 8, 2015 08:34 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
