Do the LCA pivot bolts need to go in a specific direction?
Old Jun 5, 2019 | 04:25 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
The manual says they do, but clearance-wise, for the front ones, I went the other way. I looked at the bolts and they look the same from each end.
Old Jun 5, 2019 | 04:45 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Re: Do the LCA pivot bolts need to go in a specific direction?
The direction has to do with the possibility that the up/down motion of the a-arm could cause the nut to loosen, the data suggested this configuration was least likely. I've seen them installed opposite, and also alternating. The engineers had a reason to state it, but is it likely to cause an issue that is something you will have to decide.
whitedevilTA
Apr 9, 2011 12:57 AM
Darkshot
Aug 5, 2009 07:35 PM
Iroczracer
Sep 18, 2007 10:34 PM
scanman717
May 10, 2004 01:45 PM
