Rear passenger spring getting hung up
Old Oct 14, 2019 | 02:22 PM
BlackBerlinetta's Avatar
Car: 86 Berlinetta
Hi All,
I recently replaced the original springs on my car and the ride is much better, but the back passenger side spring is getting hung up on a lip above where the panhard bar bolts on.
In fact, the spring seems to be making contact at all times in this area. I tried to pay attention to the "clocking" of the bushing when I removed them. Is there something I could have overlooked during installation?
I'll try to snag a picture later this evening.
Old Oct 14, 2019 | 08:25 PM
Re: Rear passenger spring getting hung up
Photos definitely would help. Also the spring part #s and specs you're using.
Old Oct 15, 2019 | 07:38 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I had 5 inch diameter springs with weight jacks. The springs were too short and flopped around when the axle drooped. A coil often got caught on the backside when dropping the car down from the air. I always had to put the car on jack stands and lift the axle up while guiding the spring by hand. The coil will clear once the spring is compressed enough and straightens out.
The problem went away when I installed longer springs that don't fall out of the pocket. I had to custom order those springs to my measurements.
Old Oct 16, 2019 | 06:48 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Sounds like the top of the spring isnt seated in the pocket correctly.
Old Nov 5, 2019 | 06:24 AM
McLovin1181's Avatar
Are you using the UMI weight Jack's?
Because I have the same issue on the passenger rear. (200lbs rear, 10.5in tall 5in spring)
It slightly falls out of the pocket and clunks back in when I'm going hard at the autocross.
That same side also doesn't seem to lower the car as much as the driver rear.
I can't go lower than 26in ground to fender, and a longer spring would keep my ride height too high.
Old Nov 8, 2019 | 07:55 AM
Colt's Avatar
Car: '89 Formula
Engine: 383 Megasquirt
Axle/Gears: 7.625
I have this same issue on my car, my spring rubs in the same spot. When you lower the car, the rear axle moves farther back due to the arc it follows. This is why the spring touches the panhard bar mount. The suspension was never designed to run low like this.
I have tubular lower control arms with rod-ends on them and I was able to screw the rod-ends farther in to shorten the control arms and bring the axle more forward. But when I did this, the sway bar end links got pushed to a really bad angle and messed up how how the sway works, so i had to move it back. I like the idea of moving the rear axle to where its supposed to be as it keeps the springs and shocks perpendicular with the axle, but its going to take relocating the chassis swaybar link pickups to get it done.
The font swaybar link pickups dont do well either when the car is lowered...
Old Nov 12, 2019 | 02:57 PM
Car: 86 Berlinetta
Hi All,
Sorry for the late reply. Busy couple of weeks at work.
I solved the issue. I used variable rate springs when I replaced the originals thinking it would not make a difference in fitment...
Last night I installed the "regular" style springs and it no longer makes the annoying scrubbing/banging when I hit a bump. The variable springs coils were closer towards the top and were getting caught on the panhard mount.
Thanks,
customblackbird
Aug 15, 2021 10:16 PM
customblackbird
Dec 21, 2008 10:10 PM
JamFitz
Apr 12, 2007 11:50 AM
Kandied91z
Mar 22, 2003 02:37 PM
ThirdGenZ28 92
Oct 24, 2002 08:10 AM
