Ride quality
Old Mar 26, 2020 | 05:55 PM
fonzie85's Avatar
Car: 89 IROCZ
Engine: Forged 347 LS1
Transmission: Built 4L60E with 4k stall
Axle/Gears: 4th gen w/ 3.42 gears
Ride quality
I love the way my looks right now but with the current setup I'm really unhappy with the ride quality to the point it makes me now want drive it. Right now the car is sitting a set of 18"s 245/40s in the front and 275/40s in the rear. I has eibach sportslines with half a coil cut off the front and Bilstein shock/struts.
My intentions with car are to go on more curise and just be able to drive it with being bounced all over. I only plan on taking to the strip once in a while so performance is that important to me any more. I was thinking of going back to stock springs and 16" wheels.
I know this will help but the question is how much? Is once thing better to try first instead of both at once?
Old Mar 26, 2020 | 10:44 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: Ride quality
These cars were not made for a luxury type ride, I recall when I bought my -kids now-'89 IROC, every pebble in the road could be felt.
Maybe switch to a different tire/wheel combo that mimics a passenger car and have your 3rdgen look like poo?
Old Mar 27, 2020 | 12:35 AM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
Re: Ride quality
"Bounce" is a function of the shock. How quickly/jarringly the suspension is returned to ride height after the shocks do their thing. Springs determine the ride height. Shocks, a simplified explanation, are a timing device. So "bounce" is a function of the shocks ability to return to ride height in time.
Many more variables, but that is the skinny explanation.
You've cut a half a coil off the Sportlines - who knows what that means, quantitatively. You're on 18/40's which is not necessarily bad, but problematic, if you don't have a knowledgeable/systemic approach - who knows what else you've changed. You've made decisions according to a 'look,' but now don't like the ride quality.
'Bounce' is a function of the shock/strut. Learn/search/knowledge will lead you to the solution.
Good Luck
1987 white gta
Dec 2, 2013 06:20 AM
Camaroz2892
Apr 26, 2013 12:08 AM
joef2002
Dec 17, 2011 08:17 PM
Dean92RS
Dec 18, 2003 09:29 PM
S!MON
Mar 23, 2003 03:39 PM
