Braided steel front brake lines
Old Jan 14, 2002 | 08:09 AM
Mikey G's Avatar
Car: 85 Trans Am
Engine: LB9
What brands of braided steel front brake lines are people using? Where did you get them? How much did they cost?
Old Jan 14, 2002 | 09:08 AM
Gta-Paladin's Avatar
Earls performance plumbing
(Holley)
And then there is Russell
Both can be found in summit starting at around $70
Old Jan 14, 2002 | 09:11 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I have the Earl's braided stainless brake line kit.Made more of a difference than I imagined it would, and they were easy to install.Originally was going to order the Russell set, but they were out of stock at Summit, so they suggested the Earl's .Don't think there's really any difference between the two.Think I paid about $70.
Pedal is noticeably firmer.
-Rich-
Old Jan 14, 2002 | 01:16 PM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
... make sure you get the 5 hose kit. Lf Ft, Rt Ft, Lf Rr, Rt Rr and body-2 axle. Not sure if the stuff in Summit is.
Ground Control has the kit but it's ~ 130 bux.
Old Jan 14, 2002 | 03:35 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
I don't know about Earl's but beware of the Russell lines. The body-to-axle line has a weak spot in it (specifically the "T" fitting on the rear end) and can break fairly easily.
I know two people who broke theirs while working on their cars (a small bump is all it took) and mine broke mysteriously from daily driving. Fluid all over the rear end and brakes went mush. I've taken this up with Russell and am sending them the broken lines. They tell me they're going to show them to R&D.
Old Jan 14, 2002 | 04:36 PM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
Are these DOT legal, I was under the impression they weren't? Thanks.
Old Jan 14, 2002 | 04:48 PM
Car: 92 Camaro RS
Yep, the Earl's and Russel's are DOT Approved.
-Rich-
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
