Tips on installing home-made SFC's
Old Jan 14, 2002 | 07:40 PM
Milner86's Avatar
I have decided to try an make my own sub-frame connectors, i think ive already got a pretty good idea for a pattern for them. What i need to know is the correct way to install them from someone who really knows what they are talking about. I know everything has to be dead even all the way around the chassis but what should i use to achieve this. Jack stands, ramps etc.?
Old Jan 18, 2002 | 04:15 PM
ede's Avatar
ede
park the car on a known level surface and take soem readings with an angle finder. jack all 4 cornors up and put jack stands under the control arms and rear end, so it's loaded just likes it's sitting on the gound. use 1/4" and 1/2" ply wood shims to put under the jack stands so you can replicate the measaurements you took on a level surface.
Old Jan 20, 2002 | 02:48 AM
Jza's Avatar
Jza
Tip? Measure twice, cut once.
rocn7roc
Sep 21, 2021 02:16 PM
NinjaNife
Aug 23, 2015 11:49 AM
theshackle
Aug 22, 2015 06:52 PM
BurlyChev
Aug 22, 2015 11:42 AM
Hello, Michael
Aug 20, 2015 03:19 PM
