Need help with suspension.. car to low 92 camaro
Old Apr 19, 2021 | 08:19 PM
Ozzy1992z28's Avatar
Car: 1992 z28
Engine: 305 tpi
Hi guys
I reacently got a new exaust on my car and it hangs lower than the factory exaust. I have a 92 camaro with factory suspension on the car and i would love to raise the car a few inches. Can anyone tell me what type of suspension i have and recomend some parts. Any help is appreciated
Old Apr 20, 2021 | 07:43 AM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
Re: Need help with suspension.. car to low 92 camaro
Why not fix the exhaust instead of raising the car? It will be a downgrade in both looks and handling.
Old Apr 20, 2021 | 08:58 AM
Abubaca's Avatar
Having the exhaust fixed would be cheaper to have done, and less work if you're a DIY guy. Hands down the better option. ...to address the actual question directly, I'm not even sure HOW to go about safely LIFTING a car that's currently at stock ride height.
Old Apr 20, 2021 | 04:26 PM
83 Crossfire TA's Avatar
This actually goes both ways:
  1. Yes, the correct approach is to get the exhaust up where it should be, but I guess you could be doing something extremely large or otherwise that it's not an option
  2. Very few of these cars are sitting at "stock" ride height. My TA seems not to have sagged as much as most, but at almost 35y/o I'm sure that it has sagged some, and it sits HIGH. Like 4x4 high. In this pic it's sitting on 26.1" tall front tires and 28" tall rear tires and you can see the front tire to fender gap is over a fist's worth. This or maybe as much as 1/2" above this is the designed stock suspension geometry, which puts it MUCH higher than most modern cars, even though these are considered very low cars. My stock high current gen SHO is lower and more of a problem to get on ramps than a lowered 3rd gen TA. If your car is sitting lower than this a new set of springs might help you out. Heck, even springs like Eibach Pro springs that lower the car some will rase some of sagged stock spring cars out there.
Old Apr 20, 2021 | 05:19 PM
Car: 1992 z28
Engine: 305 tpi
I dont think getting it fixed is an option. I live in australia and had the car converted to right hand drive and there is no room on the new drivers side of the engine at all. I had to get a custom set of headders made to squeze in there. So now im stuck with an exaust that hangs an inch and a half lower than stock. What do you guys think of a lift kit? There is one from universal car lifts that claims 4 inch lift on my 92 camaro
Old Apr 20, 2021 | 06:09 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Why do you Aussies convert cars to RH-drive? I know you drive on the wrong side of the road over there, but can't you do that with the steering wheel on the side the factory put it on? Here in America, I occasionally see cars with RH-drive, and that doesn't stop anyone from driving on the right side of the road...
Old Apr 20, 2021 | 07:54 PM
91ls1t56's Avatar
Car: 91 Z28
Axle/Gears: Moser 9" 3.70 35 spline wavetrack
G zuss, a transfer case and front axle might help.
Old Apr 20, 2021 | 08:15 PM
Car: '89 GTA
Engine: ZZ6TPI
I’d put the stock exhaust manifolds and y-pipe back on before I would jack up the suspension 4”.
Old Apr 20, 2021 | 09:34 PM
Car: 1992 z28
Engine: 305 tpi
I know its low lol im just trying to improve it even a little. Do you think new factory hight springs with 3inch spring spacers would help? Maybe strut spaces too ?
Old Apr 20, 2021 | 09:52 PM
Car: '89 GTA
Engine: ZZ6TPI
The original springs may sit a bit lower after all of these years, so sure, go ahead and replace them with new stock replacement springs.
You could use 4th gen rubber spring isolators in the rear, that will add 1” to the rear height. Not sure on the front. I don’t know of any spacers or anything that would raise it.
Old Apr 23, 2021 | 12:29 AM
Car: 1992 z28
Engine: 305 tpi
So there is a 2 inch gap from exaust to floor and id like to get it to at least 5.
I have just ordered some new heavy duty springs for front and back, some KYB mono tube shock absorbers, and some KYB struts. This combined with some coil spring spacers might get me there. Im hopeing the springs have sagged as the measurement fron the front fender to the floor is only 25 1/2 inches and i read somewhere on here it should he 27 1/2.
Hopefully the parts wont take to long to ship 🍻
Old Apr 23, 2021 | 07:13 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
On the cheap, theres always coil spring boosters/expanders..
https://www.autozone.com/parts/suspe...ner/541730_0_0
Old Apr 23, 2021 | 08:52 AM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
Those things put all the stress of the weight on a 1-2 inch spot on the coils, that is just asking for trouble. Run Rubber inserts if anything, but it will make the ride worse with either option
Old Apr 23, 2021 | 01:37 PM
Abubaca's Avatar
4 INCHES? I mean I'm all for everyone having their own opinion, but I think I'd just sell the car and buy something else before I'd LIFT the car like that! Just go back to stock exhaust!
Old Apr 23, 2021 | 03:14 PM
91ls1t56's Avatar
Car: 91 Z28
Yes fix the exhaust, lifting the car just makes it worse.
Old Apr 24, 2021 | 07:33 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Welcome to the world of long tube headers
Seth Baggstrom
Camaros Wanted
Nov 3, 2019 01:35 AM
Seth Baggstrom
Dec 7, 2016 12:32 PM
cedric85745
Mar 7, 2005 08:10 PM
