(9-Bolt) Axle shaft hitting inside carrier on reinstall.
Old May 3, 2021 | 12:21 AM
Neerclass's Avatar
Hey there TGO friends, looking for some advice.
​I'm in the middle of doing axle bearings and seals on my 9-bolt. Everything nice and pressed on, doing one side up and one side on the ground to prevent movement.
​​​BUT, in trying to put the axle back in, it's hitting on something inside the carrier and won't go any further in. If I tap it with a mallet, it just bounces back out, so the obstruction is solid. If I lift the other wheel and turn it, both sides turn, so it's definitely engaged with the splines in there.
Any ideas as to what's jamming me up here?
Did I press the bearing and collar on too far?
It seems like what I might be hitting is the other axle. So if I pressed it on too far, I'd hit the opposite axle before the race can seat in the tube. Hm.
I need the help of the TGO Hivemind.
Thanks in advance!
Old May 3, 2021 | 07:15 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: (9-Bolt) Axle shaft hitting inside carrier on reinstall.
Did you take the carrier apart? It may be that the cone and the spider splines are not aligned properly, that would be "about that much space"
Old May 3, 2021 | 07:19 AM
Neerclass's Avatar
I haven't touched the carrier. Could the cone and spider splines have become misaligned despite my not having moved anything? Very literally, only the passenger-side has come out.
Old May 3, 2021 | 08:08 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
That would make the most sense based on how much stick out the axle has. You could try pushing in while turning the axle with a breaker bar. It should only need to move a few degrees.
Old May 3, 2021 | 09:05 AM
Neerclass's Avatar
Turns out you were right. Hammering the passenger side axle out misaligned the splines on the way out.
Its all sorted out now and everything is sitting as it should.
Thank you so much!
Old May 3, 2021 | 09:22 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
I had my carrier apart and I forgot to put the second axle in when I put the case halves together and went trough this. I did what I suggested, turning with pressure and I was able to get them lined up again
irocman7
Oct 13, 2017 07:37 PM
bsn1989
Feb 24, 2014 09:31 AM
86blackbetty
Nov 25, 2012 06:15 PM
syoung_2000
Apr 21, 2012 06:25 PM
Mongoose
Aug 14, 2003 06:58 AM
