Torque Arm not lining up with 4th gen rear end.
Old Jun 16, 2021 | 02:30 PM
michigan_tbi's Avatar
Hoping someone here can help me out. Doing a fourth end rear end swap out of a 99 z28. Have new tubular rear lcas and panhard bar from UMI and everything went on great except for the torque arm. It looks as though the rear end is sitting 1" too far back and the holes won't line up. I have tried jacking the axle up and nothing has helped. Should I remove the lcas and try to bolt the torque arm up and then install them? Any help would greatly appreciated.
Old Jun 17, 2021 | 10:24 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Torque Arm not lining up with 4th gen rear end.
Hopefully you set your control arms to the same length as factory. If you did that, the tq arm will slide back and line up with the bolt holes.
michigan_tbi
Jul 21, 2021 09:35 AM
19transam89
Aftermarket Product Review
Nov 15, 2006 03:40 PM
srvfan723
Nov 29, 2004 04:53 PM
JamesC
May 27, 2004 01:55 PM
Twilightoptics
Jun 15, 2002 02:02 PM
