Torque Arm not lining up with 4th gen rear end.
Old Jun 16, 2021 | 02:33 PM
michigan_tbi's Avatar
Hoping someone here can help me out. Doing a fourth end rear end swap out of a 99 z28. Have new tubular rear lcas and panhard bar from UMI and everything went on great except for the torque arm. It looks as though the rear end is sitting 1" too far back and the holes won't line up. I have tried jacking the axle up and nothing has helped. Should I remove the lcas and try to bolt the torque arm up and then install them? Any help would greatly appreciated.
Old Jun 16, 2021 | 03:37 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: Torque Arm not lining up with 4th gen rear end.
Slide it back?
It might be easier to mount the torque arm to the axle, then mount it to the trans.
Old Jul 21, 2021 | 09:35 AM
camaroguy1's Avatar
Car: 84 Camaro Z28
Engine: 355
Axle/Gears: 4th gen 3.73
if you haven't already solved this, It's significantly easier to do the bolts on the axel and then the rubber mount on the transmission.
michigan_tbi
Jun 17, 2021 10:24 AM
19transam89
Aftermarket Product Review
Nov 15, 2006 03:40 PM
srvfan723
Nov 29, 2004 04:53 PM
JamesC
May 27, 2004 01:55 PM
Twilightoptics
Jun 15, 2002 02:02 PM
