You Guys With Lowered Thirdgens...
Old Aug 12, 2021 | 01:46 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
How many of you guys can no longer fit a floor jack under the K-member after lowering?...
Old Aug 12, 2021 | 03:06 PM
skinny z's Avatar
Re: You Guys With Lowered Thirdgens...
Up until I got a low profile jack, I wasn't able to.
​​​​​​What bothers me more though is that the k-member is so far in from the front the car (worse with full GFX as opposed to a sport coupe with no chin spoiler) that getting a few initial reasonable strokes of the jack handle is almost impossible.
Old Aug 12, 2021 | 03:37 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
I got to drive up on some 1" thick wood planks if I need to get under the k-member and thats with a race jack.
Old Aug 12, 2021 | 03:39 PM
skinny z's Avatar
That's our trick for the two post lift.
Old Aug 12, 2021 | 04:08 PM
T.L.'s Avatar
Yeah well I could no longer stand how the front sat higher than the rear, so I finally pulled the Z-28 springs back out (which was easy) and cut a half-coil off, then re-installed them (which was a P.I.T.A.!). I was expecting a 3/4 to 1 inch drop, but it actually dropped 1-1/4 inch. I am real happy with the stance now, but then noticed that my floor jack won't slide under the K-member anymore. Oh well...
Old Aug 12, 2021 | 04:12 PM
ughmas's Avatar
Car: '90 Formula '88 GTA
Engine: 305 TPI 350 TPI
Transmission: T5 700R4
Axle/Gears: 3.42 10 Bolt 3.27 9 bolt
drive it onto small wooden ramps first, easy fix
FORDPOWERDCHEVY
Mar 15, 2007 06:48 PM
MiTHRiL
Northern California
63
Oct 30, 2006 12:30 AM
SuPeR SpOrT
Oct 9, 2002 05:48 PM
