Front & Rear Stabilizer Bar Bushings 1984 T/A
Old Feb 4, 2022 | 03:14 PM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
The suspension(?)/performance option on my car is WY5.
I measured the front stabilizer bar as 33 mm or 1.29 Measured rear bar as 23 mm or .91 "
Do those measurements seem correct? I am removing the stab bars to repaint & though might as well replace the bushings.
Old Feb 4, 2022 | 04:03 PM
Re: Front & Rear Stabilizer Bar Bushings 1984 T/A
More or less correct. 32/23 were the usual actual values if memory serves.
Get poly bushings & end links. For the bushings, use the next smaller SAE size than the metric equivalent. Like, for 32mm, that works out to 1.259"; use 1-3/16" rather than 1¼" like would seem to be the right one. Use 7/8" for the 23. End links want to be about 2¼" or 2½", both front & rear; choose whatever length makes the "arms" of the bars sit level. You can get em from board sponsors, Summit/Jeg's, your local speed shop, or even the parts store on the corner might have em, usually in Energy Suspension.
You'll find that the bushings & links are probably the biggest bang for the buck improvement you can make to the car's feel. It's utterly astounding sometimes. Especially considering it's WAY under $100 for the whole enchilada. Next biggest bang/buck is rear springs & shocks; around $150 for the package and maybe an hour and a half of work, and again, you won't believe the difference.
Old Feb 4, 2022 | 04:19 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
ccusum
May 10, 2013 05:34 PM
badseed71386
Aug 26, 2004 05:22 PM
