Any way to convert 10 bolt leaf spring rear end to match coils in the rear end of my8
Car: 87 z28 camaro convertible
Hello guys I'm new to the car game and I'm learning.. I have an 87 Camaro that I bought looking looking to change the rear end to a higher gear ratio and posi traction. I got ahead of myself and bought a rear end that has Leave Spring purchs and needed coil. Any conversion kits or ideas?
Re: Any way to convert 10 bolt leaf spring rear end to match coils in the rear end of
Short answer: no.
In addition to the spring difference, you would also need to provide a Panhard bar mount, torque arm mount, and about 1¾" of length at each end.
Sounds like you bought a 2nd gen Camaro/Firebird rear instead of 3rd gen. Sell it and buy what you need.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Sell the rear you bought and rebuild your 3rd gen rear with a new posi carrier and gears of your choice.
Car: 1983 Z28
Engine: 385 Fastburn
This. Or if that is intimidating you can spend some time looking for a 3rd gen rear for sale with the gears you want and a posi already in it. 10-bolt or 9-bolt will both bolt right up. 10-bolts are easier to find parts for, 9-bolts have more expensive parts but are stronger.
CamaroIROC88350
Sep 6, 2010 04:16 PM
